Home » Modeling » TMF (Xtext) » Which IValidationIssueProcessor should I use?
| Which IValidationIssueProcessor should I use? [message #991156] |
Mon, 17 December 2012 10:04  |
Stephan Herrmann Messages: 781 Registered: July 2009 |
I need to programatically trigger re-validation of all xtext resources in the workspace / in a project (after changing warning severities via preferences).
I took inspiration from ValidateActionHandler and ValidationJob, but then I got confused which IValidationIssueProcessor I should use, since when simply copying code from ValidateActionHandler the error markers in the editor where no fully updated. Removing markers seemed to work, adding markers created the gray variants signaling some stale state.
The only solution I found was to use *both* an AnnotationIssueProcessor (if an editor can be found for a given file) *and* a MarkerIssueProcessor.
If I see correctly, the AnnotationIssueProcessor is responsible for handling markers in the editor and the MarkerIssueProcessor provides markers for the Problems view, is this correct?
If so, could it be that ValidateActionHandler is actually buggy in this respect? It prefers a MarkerIssueProcessor if an IResource could be found, missing to fully update markers in the editor.
thanks,
Stephan
[Updated on: Mon, 17 December 2012 11:38] Report message to a moderator
| Re: Which IValidationIssueProcessor should I use? [message #991255 is a reply to message #991156] |
Tue, 18 December 2012 02:02   |
Sebastian Zarnekow Messages: 2788 Registered: July 2009 |
Hi Stephan,
you should consider to trigger the Xtext builder for the affected
projects instead of validating everything by yourself.
Your conclusion about the IValidationIssueProcessors is correct: the
AnnotationIP will update annotations whereas the MarkerIP handles the
markers on IResources.
The ValidateActionHandler should update the annotations and markers if
you do not change the settings for the validation inbetween. Otherwise
there is a bug somewhere.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 17.12.12 16:04, schrieb Stephan Herrmann:
> I need to manually trigger re-validation of all xtext resources in the
> preferences).
> thanks,
> Stephan
| Re: Which IValidationIssueProcessor should I use? [message #992301 is a reply to message #991352] |
Fri, 21 December 2012 05:08   |
Hi Stephan,
see inline.
Am 18.12.12 17:45, schrieb Stephan Herrmann:
> Hi Sebastian,
> Sebastian Zarnekow wrote on Tue, 18 December 2012 08:02
> I did consider that option, and decided against because
> - I don't want to trigger any generation, just validation
Do think there's an issue with that? Is the generation too expensive? If
a generator produces identical files, it'll usually skip those so no
IResource changes will be propagated.
> - I didn't find an example demonstrating a build is actually easier than
> triggering validation for all relevant resources :)
IProject.build(int, String, Map<String, String>, IProgressMonitor)
should do the trick. You may even want to consider using the
org.eclipse.xtext.builder.impl.BuildScheduler.scheduleBuildIfNecessary(Iterable<IProject>,
IBuildFlag...) which takes care of repeatedly scheduled builds for the
very same projects.
> Quote:
> Sorry for being dense: What exactly is the Xtext editor showing?
> Annotations and/or Markers?
The editor's always showing annotations. Markers are converted to
annotations. If you edit the file to fix such an error, the annotations
will be updated, markers stay the same until you save the thing.
> Quote:
> Well, the code in ValidateActionHandler shows that exactly one of the
> issue processors is used, never both.
You are right, only one of the processors is used. The annotation model
listens to changes on the IResource to update the annotations as soon as
the markers change
(ResourceMarkerAnnotationModel.update(IMarkerDelta[]). Which implies
that existing annotations that do not reflect that state on disk will
not be updated if you trigger validation. Actually markers will be
persisted that do not match the content of the file on disk. This is a
bug. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=397065
> best,
> Stephan
| Re: Which IValidationIssueProcessor should I use? [message #992329 is a reply to message #992301] |
Fri, 21 December 2012 06:14   |
Hi Sebastian,
Sebastian Zarnekow wrote on Fri, 21 December 2012 11:08
Well, generation isn't for free . It may be acceptable even with 100 DLS files, but I'm sure once we approach 1000 files the difference will hurt. From work with large workspaces we know that "build all" should be avoided to the extent possible, right?
OTOH, your suggestion to do more work than necessary must have a reason. If it's code simplicity, I don't mind the lines I had to implement to trigger validation only. Is building a project optimized so that, e.g., resources are read more efficiently than when I trigger it myself?
Thanks, I should've known.
But wait: to trigger re-validation without source changes I'd need to pass FULL_BUILD, and then, if the project also has other builders, they will do a full build, too. Not a good idea
very same projects.
Cool, I'll take a look into that one.
Do you consider that class API (I see a suspecious "impl" in the package name)?
Thanks for identifying the root issue. I've subscribed to that bug so I can update my implementation, once that bug is addressed.
thanks,
Stephan
| Re: Which IValidationIssueProcessor should I use? [message #992536 is a reply to message #992329] |
Fri, 21 December 2012 17:31   |
Hi Stephan,
please find my comments inline.
Am 21.12.12 12:14, schrieb Stephan Herrmann:
> Hi Sebastian,
> Well, generation isn't for free :). It may be acceptable even with 100
Agreed.
Depending on the size of your resources, loading all of them into memory
may be problematic. The builder uses a clustering strategy to reduce the
max amount of memory that is necessary. In other regards, that one is
not optimized, no.
> Quote:
> Thanks, I should've known. But wait: to trigger re-validation without
> also has other builders, they will do a full build, too. Not a good idea :)
Didn't know that. I thought other builders would not be triggered if a
concrete builder ID is passed.
> Quote:
>> very same projects.
> Cool, I'll take a look into that one. Do you consider that class API (I
API in a sense that we are not inclined to change it right now: yes. In
a sense that it is carved in stone: no. Anyway, all the packages from
the builder bundle are marked as internal.
> Quote:
Since we are working on customizable severities as part of the
validation API, it's quite likely that we'll come up with a reasonable
solution to that problem.
I wish you nice holidays,
Sebastian
> thanks,
> Stephan
Current Time: Fri May 24 17:47:30 EDT 2013
Powered by FUDForum. Page generated in 0.01740 seconds
