Home » Eclipse Projects » Remote Application Platform (RAP) » Padding Issue(Padding issue in RAP 1.5)
Padding Issue [message #991113] Mon, 17 December 2012 06:56 Go to next message
Arif Sorathia is currently offline Arif Sorathia
I am using org.eclipse.rap.rwt.theme.Default theme with custom css style file.
currently I am unable to trim the upper and left side padding from my application, you can view the RED selected area in the following image.
www.binaryvibes.net/1.png
i want to exclude the padding from top and left area
any idea??
Re: Padding Issue [message #991198 is a reply to message #991113] Mon, 17 December 2012 12:06 Go to previous messageGo to next message
Ronald So is currently offline Ronald So
I can't see your image. The link is broken.
When you do styling, make sure you also check the padding on the Composite where your image lives. The problem may not be caused by the image CSS settings, but the Composite padding settings that you have ignored.
Good luck.
Re: Padding Issue [message #991742 is a reply to message #991198] Thu, 20 December 2012 00:00 Go to previous message
Thank you.. issue resolved
Previous Topic:Application beforeDestroy() never gets called during browser close
Next Topic:Overlays via custom widget?
Current Time: Fri May 24 11:19:29 EDT 2013
Powered by FUDForum. Page generated in 0.35851 seconds
