Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Clean EMF install: Project does not exist?
Clean EMF install: Project does not exist? [message #99107] Sun, 14 October 2007 09:35 Go to next message
Eclipse User
Originally posted by: mielzpost.gmail.com
Sorry for the crosspost but i posted it in modeling, so i better post it
here, my apologies.
Dear All,
I've 'installed' a copy of Eclipse 3.3.0, with EMF 2.3.0.v2 under Vista.
And as soon as i try to start a new project it gives me the following
error:
The project was not built due to "[PROJECTNAME HERE] does not exist". Fix
the problem, then try refreshing this project and building it since it may
be inconsistent
I've also tried to install OAW and but same results. It seems like i cant
build anything, while i've installed practically everything. Actually im a
c#/.net guru, but your EMF DSL tools kick so much ass i just had to
install it, too bad i cant get it too work. Who has any ideas?
Emile Bosch
Re: Clean EMF install: Project does not exist? [message #99122 is a reply to message #99107] Sun, 14 October 2007 11:41 Go to previous messageGo to next message
Eclipse User
--------------070002030401060506030706
Emile,
Did you install using the zip files? Did you run eclipse.exe with
-clean? You're sure you're running with a JDK 5.0 or greater? Try
clearing the Error log view and starting Eclipse again with -clean
-debug and check that the Error log view doesn't contain messages about
plugins that are failing to activate. Is the error message really
complaining that project X which you created cannot be built because
project X doesn't exist? Can you create a basic Java project that
works? How exactly did you create the project?
Note Reinhold Bihler is working on a C# version of the EMF runtime. He
plans to create an EMFT component for it soon. You might be interested
in it:
<http://www.emf4net.org/>
> it here, my apologies.
> Dear All,
> Vista. And as soon as i try to start a new project it gives me the
> following error:
> Fix the problem, then try refreshing this project and building it
> since it may be inconsistent
> cant build anything, while i've installed practically everything.
> Actually im a c#/.net guru, but your EMF DSL tools kick so much ass i
> just had to install it, too bad i cant get it too work. Who has any
> ideas?
> Emile Bosch
<html>
<head>
http-equiv="Content-Type">
</head>
Emile,<br>
<br>
Re: Clean EMF install: Project does not exist? [message #99537 is a reply to message #99122] Wed, 17 October 2007 17:18 Go to previous message
Eclipse User
Ed, thanks
I will try to create a new install,
I must say, Java modeling is sure looks superior to ms dsl solutions,
To the way the java community uses it looks fairly limited, for instance,
i would use a dsl for creating not only code, but also use it for manual
and procedure generation. Documenation. Configuring of CRM, AX, nav etc.
Keep up the good work! (Sometimes i wish i was a java dev myself)
Emile Bosch
Re: Clean EMF install: Project does not exist? [message #610004 is a reply to message #99107] Sun, 14 October 2007 11:41 Go to previous message
Ed Merks is currently offline Ed Merks
Emile,
in it:
> Dear All,
> following error:
> ideas?
> Emile Bosch
<html>
<head>
</head>
Emile,<br>
<br>
Re: Clean EMF install: Project does not exist? [message #610061 is a reply to message #99122] Wed, 17 October 2007 17:18 Go to previous message
Eclipse User
Ed, thanks
Emile Bosch
Previous Topic:[Compare] extensibility
Next Topic:[Compare] extensibility
Current Time: Wed May 22 21:37:27 EDT 2013
Powered by FUDForum. Page generated in 0.04648 seconds
