Hi all
I'm trying to test my language serializer but i get some errors I don't understand, so I need your help please.
Given these production rules:
ActualParameters:
{ActualParameters} '(' (expressions+=Expression (',' expressions+=Expression)*)? ')'
MethodCall:
receiverObject=Expression '.' mixinName=ID '.' methodName=ID params=ActualParameters
Expression:
TerminalExpression ({Expression.expr=current} '.' mixinName=ID '.' memberName=ID actualParams=ActualParameters?)*
TerminalExpression returns Expression:
{ThisExpr} 'this' |
{NullExpr} 'null' |
{FalseExpr} 'false' |
{TrueExpr} 'true ' |
{StringLiteralExpr} stringLiteral=STRING_LITERAL |
{NumberLiteralExpr} numberLiteral=NUMBER_LITERAL |
{IdentifierExpr} identifier=ID |
{ObjectCreationExpr} objectCreation=ObjectCreation |
{SuperExpr} 'super' actualParams=ActualParameters |
{ParenthesizedExpr} '(' parenthesizedExpr=Expression ')'
ParamAssignment:
mixinName=ID '.' paramName=ID ':=' assignedValue=Expression
ParamAssignments:
{ParamAssignments} (paramAssignments+=ParamAssignment (',' paramAssignments+=ParamAssignment)*)?
...I'd like to create - via language factory - an EObject representing the method call "this.Point2D.setCoords2D(10, 20)", and then serialize it, printing the resulting string (expected to be that one), but this code:
Injector injector = Guice.createInjector(new MyLanguageRuntimeModule());
Serializer serializer = injector.getInstance(Serializer.class);
MethodCall methodCall = MyLanguageFactory.eINSTANCE.createMethodCall();
methodCall.setReceiverObject(MyLanguageFactory.eINSTANCE.createThisExpr());
methodCall.setMixinName("Point2D");
methodCall.setMethodName("setCoords2D");
ActualParameters params = MyLanguageFactory.eINSTANCE.createActualParameters();
NumberLiteralExpr param1 = MyLanguageFactory.eINSTANCE.createNumberLiteralExpr();
param1.setNumberLiteral("10");
NumberLiteralExpr param2 = MyLanguageFactory.eINSTANCE.createNumberLiteralExpr();
param2.setNumberLiteral("20");
//I'm not sure the underlying code is correct :-/
//how can I add a NumberLiteralExpr to the "expressions" collection of a ActualParameters object?
params.getExpressions().add(param1);
params.getExpressions().add(param2);
methodCall.setParams(params);
System.out.println(serializer.serialize(methodCall));
generates these errors
org.eclipse.xtext.parsetree.reconstr.XtextSerializationException: Serialization failed
<# of serialized tokens>: <EObject path> "<serializable fragment, starting from the end>":
-> <possible reasons for not continuing>
13:MethodCall.params->ActualParameters: "( 20 )":
-> ActualParameters_ActualParametersAction_0: n/a
11:MethodCall.params->ActualParameters.expressions[1]->NumberLiteralExpr: ")":
-> TerminalExpression_NumberLiteralAssignment_5_1: n/a
5:MethodCall.params->ActualParameters: "( )":
Could you please help me?
Thanks in advance,
Marco
[Updated on: Fri, 14 December 2012 06:54]
Report message to a moderator
