Home » Eclipse Projects » Jubula » Move test suite to another project(question about how to move test suite from one project to another)
Move test suite to another project [message #990830] Fri, 14 December 2012 06:31 Go to next message
Erik Gilbert is currently offline Erik Gilbert
Member
I have a test suite defined in one project. How can I move this test suite to another project?
and together with it's corresponding test cases?
[Updated on: Fri, 14 December 2012 06:34]
Report message to a moderator
Re: Move test suite to another project [message #997535 is a reply to message #990830] Tue, 08 January 2013 02:46 Go to previous message
Alexandra Schladebeck is currently offline Alexandra Schladebeck
Test Cases can be moved using the "move to external project" function (this removes them from the current project, adds them to the reused project and updates the references). It's designed so that you can build library projects even once you have started specifying. Moving Test Suites is not possible. If you can elaborate on why you want to move the Test Suite, I may be able to suggest an alternative.
HTH,
Alex
Previous Topic:HTML AUT fails to start with exception
Next Topic:Associating component names as parameters
Current Time: Wed May 22 23:06:42 EDT 2013
Powered by FUDForum. Page generated in 0.01609 seconds
