Home » Modeling » EMF » [Xcore] Defining get on derived features using reflective feature delegation
[Xcore] Defining get on derived features using reflective feature delegation [message #990824] Fri, 14 December 2012 06:04 Go to next message
Christoph Keimel is currently offline Christoph Keimel
Hello
is it possible to define get for features when reflective (or dynamic) feature delegation is used?
Example:
@GenModel(featureDelegation="Reflective")
class MyClass {
	String name
	String firstName
	derived String fullName get {
		name + ", " + firstName
My tests show that this is not implemented using EMF 2.8.1 and Xcore 1.0.1. Are there any plans to support this?
Greetings
Christoph
Re: [Xcore] Defining get on derived features using reflective feature delegation [message #990829 is a reply to message #990824] Fri, 14 December 2012 06:20 Go to previous message
Ed Merks is currently offline Ed Merks
Christoph,
Yes, this problem is related to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=385634. The guards for
when to emit the body verses what's generated otherwise is a little too
far down in the template. Perhaps you can append this example to that
bug to remind me that it needs attention; it shouldn't be too hard to fix...
> class MyClass {
> String name
> String firstName
Previous Topic:[CDO] Multi master (clone)
Next Topic:generate genmodel from schema xml
Current Time: Sat May 25 18:52:17 EDT 2013
Powered by FUDForum. Page generated in 0.01503 seconds
