Home » Eclipse Projects » BIRT » Create elements that derive from rptlibrary using Designer API(LabelHandle label = elementFactory.newLabel( null ); )
Create elements that derive from rptlibrary using Designer API [message #990692] Thu, 13 December 2012 15:07 Go to next message
ivkina Mising name is currently offline ivkina Mising name
Member
We are testing BIRT Designer API to create some reports on the fly at runtime. So far it works but we seems can't find a way how to create an item in a report that derives from an item defined in rptlibrary. For example, I can add a label to a grid dynamically:
GridHandle grid = elementFactory.newGridItem("QR_VertGrid", 2, 5);
CellHandle g_cell = grid.getCell(0, 0);
LabelHandle label = elementFactory.newLabel(null);
label.setText("Test Label");
g_cell.getContent().add(label);
but I can't find a method that would allow me to create a label that would be a subclass of the one that is defined in my rptlibrary. Is that possible?
Aleksey
Re: Create elements that derive from rptlibrary using Designer API [message #990919 is a reply to message #990692] Fri, 14 December 2012 16:37 Go to previous messageGo to next message
Member
looks like you can use elementFactory.newElementFrom(libHandle.findElement("CP_LabelCntl"), null);
where libHandle is LibraryHandle to your library. It works for labels.
However, I cannot make it work for DataItemHandle. The element seems to be created but when I run a report I am getting an error saying "data expression required". I tried this code:
ComputedColumn binding = StructureFactory.createComputedColumn();
binding.setName("MyBinding_COLUMN1");
binding.setExpression("dataSetRow[\"COLUMN1\"]");
binding.setDataType(DesignChoiceConstants.COLUMN_DATA_TYPE_DECIMAL);
table.getColumnBindings().addItem(binding);
DataItemHandle data = (DataItemHandle) elementFactory.newElementFrom(libHandle.findElement("CP_DecimalCntl"), binding.getName());
data.setResultSetColumn(binding.getName());
cell.getContent().add(data);
Michael, Jason,
Would you please take a look? The question is how to create a data item element that derives from the library using Designer API and then how to assign a dataset column to this item? This is BIRT 3.7.1. Thanks!
Re: Create elements that derive from rptlibrary using Designer API [message #991405 is a reply to message #990919] Tue, 18 December 2012 17:33 Go to previous message
Michael Williams is currently offline Michael Williams
Sorry for the delay. You're trying to add a binding to a table using the DEAPI and then also create a data element within based on a data element from your library? Is the field used, in the dataSet you use for the table? Can you possibly attach a sample library and report and describe what you're wanting to see, based on those, so I can get a good visual? Thanks!
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Previous Topic:Height of Report Viewer embedded in iframe
Next Topic:Connection Pool in Birt Viewer
Current Time: Sun May 19 02:12:43 EDT 2013
Powered by FUDForum. Page generated in 0.08015 seconds
