| java.lang.NoClassDefFoundError: javax/management/ObjectName [message #990178] |
Tue, 11 December 2012 05:03  |
daniel marthaler Messages: 11 Registered: April 2012 Location: Zürich |
Junior Member |
I am getting java.lang.NoClassDefFoundError: javax/management/ObjectName when trying to work with a ObjectName instance from javax.management in a bundle, although using springs mechanism to auto-export annotated beans is working in the same bundle.
As for my understanding of Virgo, as long as the java6-server.profile file under "org.osgi.framework.system.packages" contains an entry for the java.management* packages, these should be available to bundles using classes of it. Or am i completely wrong?
I also tried to add javax.management as bundle dependency, but also this results in a class not found exception?
Anyone any suggestions what im doing wrong here?
Cheers Dani
| Re: java.lang.NoClassDefFoundError: javax/management/ObjectName [message #990249 is a reply to message #990202] |
Tue, 11 December 2012 10:25   |
Junior Member |
Well, i have now listed all javax.management packages under packageImports
javax.management;version="0",\
javax.management.loading;version="0",\
javax.management.modelmbean;version="0",\
javax.management.monitor;version="0",\
javax.management.openmbean;version="0",\
javax.management.relation;version="0",\
javax.management.remote;version="0",\
javax.management.remote.rmi;version="0",\
javax.management.timer;version="0"
Now when i try to work with ModelMBean Interface i still get a java.lang.NoClassDefFoundError: javax/management/modelmbean/ModelMBean.
Does anybody have an idea where the problem is???
Regards Dani
FUDForum. Page generated in 0.01728 seconds
