Home » Modeling » Ecore Tools » ecore diagram: IllegalArgumentException on loadup
ecore diagram: IllegalArgumentException on loadup [message #990490] Wed, 12 December 2012 12:15
Simon Schimansky is currently offline Simon Schimansky
Hi there,
i just startet to create a rather simple ecore file using a ecorediag. However after restarting eclipse, i cant open it anymore. I get the following error message:
java.lang.IllegalArgumentException: Cannot format given Object as a Number
	at java.text.NumberFormat.format(Unknown Source)
	at java.text.Format.format(Unknown Source)
	at java.text.MessageFormat.subformat(Unknown Source)
	at java.text.MessageFormat.format(Unknown Source)
...and so on
The only change i made inside the ecore itself was the namespace, but i undid that.
You can find the files attached.
I would really like to be able to open up the file again, and hope you can help me.
SOLVED:
Quite easy... you can generate new ecorediags out of a existing ecore file via the context menu... Smile
[Updated on: Mon, 17 December 2012 06:22]
Report message to a moderator
Previous Topic:Initialize ECore diagram file only goes down one level
Next Topic:How to get files from Preject Explorer and Pakage Explorer to new View on Eclipse?
Current Time: Tue May 28 11:00:51 EDT 2013
Powered by FUDForum. Page generated in 0.06888 seconds
