| using cdt eclipse and cygwin to create .so shared object on windows 7 [message #990484] |
Wed, 12 December 2012 11:30  |
Greg Mort Messages: 2 Registered: December 2012 |
Junior Member |
I have Eclipse CDT installed (juno) on my windows 7 computer I have cygwin installed (able to manually create a makefile and create a .so)
I want to use the cygwin compiler in eclipse to create a .so
I created a new shared library project in eclipse told it to use the cygwin c++ compiler
do a ctrl-b and it creates a .dll
how do I get it to make a .so?
this is using windows 7
11:13:05 **** Build of configuration Debug for project cygwinc++ ****
make all
Building file: ../main.cpp
Invoking: Cygwin C++ Compiler
g++ -O0 -g3 -Wall -c -fmessage-length=0 -MMD -MP -MF"main.d" -MT"main.d" -o "main.o" "../main.cpp"
cygwin warning:
MS-DOS style path detected: C:\Users\EAIGREG\workspace\cygwinc++\Debug
Preferred POSIX equivalent is: /cygdrive/c/Users/EAIGREG/workspace/cygwinc++/Debug
CYGWIN environment variable option "nodosfilewarning" turns off this warning.
Finished building: ../main.cpp
Building target: cygwinc++.dll
Invoking: Cygwin C++ Linker
g++ -shared -o "cygwinc++.dll" ./main.o
cygwin warning:
Finished building target: cygwinc++.dll
11:13:06 Build Finished (took 390ms)
clearly this is using the wrong compiler... i know that my cygwin can create SO so how to i tell it to use the "linux" c++ compiler?
FUDForum. Page generated in 0.03390 seconds
