| [EEF] Problems with references to other models [message #990479] |
Wed, 12 December 2012 11:18 |
Erlend Stav Messages: 5 Registered: September 2012 |
Junior Member |
I am trying to generate an EEF editor for an .ecore model that contains a reference to another .ecore model. Is this supported in EEF? I first tried this in the context of creating an ecore model that is used for decorating / referring to a UML model, but to troubleshoot the problems I experienced, I have now a more minimal setup with only two ecore models.
In my experiment I created a small example with a generated EEF editor that works fine. For simplicity, lets call it Ex1 containing class A. Then I create Ex2 which imports A from Ex1 and which defines class B which have a reference to A. The loading of Ex1 from Ex2 was done by browsing the workspace in this case (but I also had the same problem when importing from the registered uml.ecore in my original attempt).
When trying to use "Initialize EEF Editor" the .genmodel is created but the src-gen directory that appears is empty. The .edit and .editor projects are created, but their src-gen end up with a single class (...EditPlugin and ...EditorPlugin). The models files under the .edit project are created, but the .components models contain only the root entry with no sub-content.
Any ideas? Are imports supported at all in EEF?
FUDForum. Page generated in 0.03643 seconds
