Home » Modeling » MoDisco » How to specifiy query parameters in the Query Executions view?
How to specifiy query parameters in the Query Executions view? [message #990398] Wed, 12 December 2012 04:58 Go to next message
Andreas Brieg is currently offline Andreas Brieg
Member
I have a Java Query that takes an EString as Parameter. I would like to specify that parameter in the Query Executions view. However I don't see any action that would do this in that view. Selecting Execute results in a NPE in the Java code of the query, because the parameter is null. Isn't this (yet) possible?
Re: How to specifiy query parameters in the Query Executions view? [message #990439 is a reply to message #990398] Wed, 12 December 2012 08:56 Go to previous messageGo to next message
Hugo Bruneliere is currently offline Hugo Bruneliere
The current version of the UI does not support the handling of queries with parameters.
However, by directly using the MoDisco Query API, you will be able to run such queries (cf. the Query Manager/Developer Documentation section of the MoDisco Reference Documentation for having a concrete example of this).
I hope this helps.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Re: How to specifiy query parameters in the Query Executions view? [message #990465 is a reply to message #990439] Wed, 12 December 2012 10:41 Go to previous message
Member
Yes. That helped. However I think I'm currently faster with hard coding parameters in the java query implementation.
Previous Topic:MetaModel AdapterFactories
Next Topic:KDM Model Creation from C++ code?
Current Time: Tue May 28 18:52:29 EDT 2013
Powered by FUDForum. Page generated in 0.01443 seconds
