Home » Eclipse Projects » Libra » WAR Validate Null Pointer Exception(WAR Validate fails on some projects)
WAR Validate Null Pointer Exception [message #989987] Mon, 10 December 2012 05:55 Go to next message
John Gymer is currently offline John Gymer
Member
Using Eclipse 4.2.1, RAP 2.0 M3 tooling, and WAR Products (incubation) from Libra 0.2.0.201206060754... Trying to do a Validate or an Export of War Product gives this error in Eclipse Error Log:
	at org.eclipse.libra.warproducts.ui.validation.WARProductValidateAction.isBanned(WARProductValidateAction.java:152)
	at org.eclipse.libra.warproducts.ui.validation.WARProductValidateAction.validateErrors(WARProductValidateAction.java:136)
	at org.eclipse.libra.warproducts.ui.validation.WARProductValidateAction.varifyPDEErrors(WARProductValidateAction.java:121)
	at org.eclipse.libra.warproducts.ui.validation.WARProductValidateAction.verifyResult(WARProductValidateAction.java:100)
	at org.eclipse.libra.warproducts.ui.validation.WARProductValidateAction.validate(WARProductValidateAction.java:91)
	at org.eclipse.libra.warproducts.ui.validation.WARProductValidateAction.run(WARProductValidateAction.java:59)
	at org.eclipse.libra.warproducts.ui.exportwizard.ExportWARProductWizard.validateProduct(ExportWARProductWizard.java:112)
	at org.eclipse.libra.warproducts.ui.exportwizard.ExportWARProductWizard.loadProductFromFile(ExportWARProductWizard.java:93)
	at org.eclipse.libra.warproducts.ui.exportwizard.ExportWARProductWizard.loadProductFromFile(ExportWARProductWizard.java:188)
	at org.eclipse.libra.warproducts.ui.exportwizard.ExportWARProductWizard.handleFileSelection(ExportWARProductWizard.java:217)
	at org.eclipse.libra.warproducts.ui.exportwizard.ExportWARProductWizard.loadProductFromSelection(ExportWARProductWizard.java:206)
	at org.eclipse.libra.warproducts.ui.exportwizard.ExportWARProductWizard.addPages(ExportWARProductWizard.java:59)
	at org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:605)
	at org.eclipse.jface.window.Window.create(Window.java:431)
	at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
	at org.eclipse.libra.warproducts.ui.editor.WARProductExportAction.run(WARProductExportAction.java:56)
	at org.eclipse.libra.warproducts.ui.editor.OverviewPage.linkActivated(OverviewPage.java:83)
	at org.eclipse.ui.forms.widgets.FormText.activateLink(FormText.java:1552)
	at org.eclipse.ui.forms.widgets.FormText.handleMouseClick(FormText.java:1355)
	at org.eclipse.ui.forms.widgets.FormText.access$16(FormText.java:1326)
	at org.eclipse.ui.forms.widgets.FormText$6.mouseUp(FormText.java:448)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:220)
This is on one specific project.
Creating a WAR for the RAP Demo project works ok, deploys ok as a WAR into WebLogic and runs ok.
Any clue what is different about my project that is stopped the WAR tooling from running the Validate? Where to start looking?
The project runs ok as SWT Standalone, and also RWT Standalone. Haven't managed to get it running as RAP yet, but hopefully this isn't relevant.
Thanks, John
Just because you can doesn't mean you should
Re: WAR Validate Null Pointer Exception [message #990441 is a reply to message #989987] Wed, 12 December 2012 08:58 Go to previous message
Member
Quick update... never got to the bottom of this, but once I finally got my application to run as a RAP app from within the Eclipse IDE, I wiped the existing WAR product configuration, started again, basing the new WAR configuration on the RAP run configuration, and hey presto, it is happy and working - I have my RAP application running successfully via a WAR within JBoss and WebLogic!
John
Previous Topic: [WAR Product] Cannot create WAR with Spring bundles (cycle+optionnal dependencies)
Next Topic:Current status for "/libra/milestones/" update site directory
Current Time: Wed May 22 04:27:45 EDT 2013
Powered by FUDForum. Page generated in 0.02841 seconds
