Home » Eclipse Projects » Rich Client Platform (RCP) » Eclipse 4 RCP getting parts via EPartService
Eclipse 4 RCP getting parts via EPartService [message #989891] Sun, 09 December 2012 10:27 Go to next message
Daniel Stingl is currently offline Daniel Stingl
Greetings,
I have another problem with my RCP Project. I am trying to hide/show some parts, and I tried to find those parts by calling EPartService.findPart("partID").
package fzi.activemq.rcp.launcher.Composites.lowerleft;
import javax.inject.Inject;
import org.eclipse.e4.core.di.annotations.Execute;
import org.eclipse.e4.ui.model.application.ui.basic.MPart;
import org.eclipse.e4.ui.workbench.UIEvents.Part;
import org.eclipse.e4.ui.workbench.modeling.EPartService;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import fzi.activemq.rcp.launcher.Composites.MainComposite;
public class SelectComposite2 extends Composite {
	@Inject private EPartService service;
	Button aMQButton;
	Button dBButton;
	public SelectComposite2(Composite parent, int style){
		super(parent, style);
		MPart part = service.findPart("fzi.activemq.rcp.launcher.part.2");
		part.setVisible(true);
When findPart gets called, I get this NullPointerException:
	at fzi.activemq.rcp.launcher.ui.parts.LowerLeft.configurationSelected(LowerLeft.java:40)
	at fzi.activemq.rcp.launcher.Composites.upperleft.SelectComposite$1.widgetSelected(SelectComposite.java:45)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:150)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Would be great if u could help me out.
thx,
Daniel
Re: Eclipse 4 RCP getting parts via EPartService [message #989931 is a reply to message #989891] Mon, 10 December 2012 02:05 Go to previous messageGo to next message
sumit singh is currently offline sumit singh
Member
The problem is
is not injected .
Why..? Because you are creating object of your SelectComposite2 class so its your responsibility to inject all necessary injection to your class. Like following.
SelectComposite2 cim = new SelectComposite2();
ContextInjectionFactory.inject(cim,iEclipseContext);
Where iEclipseContext is IEclipseContext variable. IEclipseContext automatically inject when eclipse framework will create your object . Like in case of handler.
But if you are creating your object then its your responsibility to inject it.
[Updated on: Mon, 10 December 2012 02:06]
Report message to a moderator
Re: Eclipse 4 RCP getting parts via EPartService [message #990002 is a reply to message #989931] Mon, 10 December 2012 07:23 Go to previous messageGo to next message
Thx for your reply. Is it possible to use injection similar in Listeners as in Handlers (it didnt work when I tried it but I wouldnt be that surprised if I messed that up..)?
Otherwise, how can i get my hands on an instance of IEclipseContext? Rly tried to figure that out myselve, but no matter how many sites I browse, it seems that this is only used with injection...
[Updated on: Mon, 10 December 2012 10:02]
Re: Eclipse 4 RCP getting parts via EPartService [message #990374 is a reply to message #990002] Wed, 12 December 2012 03:35 Go to previous messageGo to next message
Member
No. In case of listeners you have to do it your self. take a look of following code . you can get your EPartService like following in your class.
Bundle bundle = FrameworkUtil.getBundle(EPartService.class);
BundleContext bundleContext = bundle.getBundleContext();
IEclipseContext eclipseCtx =
EclipseContextFactory.getServiceContext(bundleContext);
EPartService  partService  = (EPartService) eclipseCtx.get(EPartService.class.getName());
[Updated on: Wed, 12 December 2012 03:36]
Re: Eclipse 4 RCP getting parts via EPartService [message #990437 is a reply to message #990374] Wed, 12 December 2012 08:55 Go to previous messageGo to next message
Thank u so much, everything is working fine now!
Re: Eclipse 4 RCP getting parts via EPartService [message #990552 is a reply to message #990437] Thu, 13 December 2012 00:45 Go to previous messageGo to next message
Member
Your Welcome Smile
Re: Eclipse 4 RCP getting parts via EPartService [message #990955 is a reply to message #990552] Sat, 15 December 2012 06:39 Go to previous messageGo to next message
Brian de Alwis is currently offline Brian de Alwis
Just to elaborate on Sumit's answer -- you need to obtain a context from somewhere. Sumit's code uses the top-level OSGi context, which works in this case as the EPartService is effectively a singleton registered as an OSGi service. But you'll find that this won't work for other services as they will be registered at other points in the context tree. Generally you should do lookups from the closest context that you can find, and many of the UI classes carry a context (see the subclasses of MContext). In Eclipse 3.x compat layer, you can obtain the IEC for a part using:
getSite().getService(IEclipseContext.class);
Brian.
Re: Eclipse 4 RCP getting parts via EPartService [message #991020 is a reply to message #989891] Mon, 17 December 2012 00:17 Go to previous message
Member
Thanks Brian to make it more clear.
Previous Topic:Disable text search
Next Topic:Error launching Eclipse Application from Vogella Tutorial
Current Time: Sun May 26 01:53:10 EDT 2013
Powered by FUDForum. Page generated in 0.08310 seconds
