| Re: [CDO] Multi master (clone) [message #990811 is a reply to message #990791] |
Fri, 14 December 2012 05:44  |
Eike Stepper Messages: 5154 Registered: July 2009 |
Am 14.12.2012 10:57, schrieb Ricky de Klerck:
> Eike,
> We found a problem in the 'org.eclipse.emf.cdo.server.db' plugin. In a few classes, for example
> 'AbstractHorizontalMappingStrategy', double quotes were added to the table alias. We've tested it with MySQL version
> 5.5.25, but it doesn't work because of these quotes.. the MySQL syntax won't accept it. When I remove the quotes,
> everything works fine again. But you must have added them for a reason, because they weren't there in the previous
> version..
That has been reverted already. Please use a newer drop. If the problem is still there, please submit a bugzilla and
tell us exactly where you've found the quotes.
Cheers
/Eike
http://www.esc-net.de
FUDForum. Page generated in 0.02742 seconds
