Home » Eclipse Projects » Web Tools Project (WTP) » [Solved] JSDT Debug Tools(How can I install the JSDT Debugging Tools?)
[Solved] JSDT Debug Tools [message #990205] Tue, 11 December 2012 06:56 Go to next message
Frank Church is currently offline Frank Church
I am trying to install the JSDT Debug tools from this page http://wiki.eclipse.org/JSDT/Debug#JavaScript_Debug_Interface_.28JSDI.29.
When I try to install via the PSF file there I get a connection error which appears to be due to a wrong username/password combination?
Am I following the right path?
Is there an alternate means to install it, preferablby by addding the site URL from the Help | Install New Software menu.
[Updated on: Wed, 12 December 2012 07:47]
Report message to a moderator
Re: JSDT Debug Tools [message #990317 is a reply to message #990205] Tue, 11 December 2012 14:56 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
The PSF file is a project interchange file, meant for loading the source projects into Eclipse, not for actually installing and using the tools. All of the debug-related sources can be found in the Git repository you can clone using git://git.eclipse.org/gitroot/jsdt/webtools.jsdt.debug.git . And yes, the PSF itself is incorrect. For installing the tools, you need only to choose the JavaScript Development Tools from the Juno repository at http://download.eclipse.org/releases/juno/ , assuming you're using Juno.
Nitin Dahyabhai
Eclipse WTP, IBM
Re: JSDT Debug Tools [message #990422 is a reply to message #990317] Wed, 12 December 2012 07:45 Go to previous message
In fact it was due to my being an Eclipse Newbie. The Debug tools where installed but they were not showing up in the options the way I thought. It took some extra work to find out.
In any case I learned something new. Smile Thanks
[Updated on: Wed, 12 December 2012 07:46]
Previous Topic:JavaTOWS Fail to load class error
Next Topic:Javascript hot refresh?
Current Time: Fri May 24 20:51:04 EDT 2013
Powered by FUDForum. Page generated in 0.05513 seconds
