| Redo/Undo Typing is not working properly for XML Files [message #990186] |
Tue, 11 December 2012 05:27  |
Stefan Mietke Messages: 1 Registered: December 2012 |
Junior Member |
after upgrading to Eclipse Juno, the Edit Redo/Undo feature is not working properly. After starting Eclipse it is working for the first time. But when switching to another file (XML file) it is unusable anymore. Is this a known problem? For Java-Files its seems to be working.
I'm using Eclipse Juno Service Release 1 (Build id: 20120920-0800) the Eclipse Java EE IDE for Web Developers 64 bit on Ubuntu 12.04 LTS.
Stefan
P.S. This is the only post I found with similar problems: https://bugs.eclipse.org/bugs/show_bug.cgi?id=372753
FUDForum. Page generated in 0.01453 seconds
