Home » Modeling » EMF » [CDO] Server replication mechanism
| [CDO] Server replication mechanism [message #990163] |
Tue, 11 December 2012 03:31  |
Alex Lagarde Messages: 124 Registered: May 2010 |
Dear CDO enthusiasts,
I've got some questions related to the IRepositorySynchronizer mechanism
in CDO, in case you have advices before I start developping my own solution.
We are currently deploying a CDO-based software for our users.
The issue is that the users are located in a city, and the CDO server in
another one. In result, the performances (especially when loading
models) are not acceptable for the end-users, because of the poor
network. On another hand, when deploying the server in their city the
users are satisfied by the tool performances.
That is why I'm currently trying to set up a replication mechanism: we
would like to have a MASTER server in city A, and a CLONE (potentially
many clones) of this server in the city B (the users's city). This will
allow to improve performances especially when loading their models, as
users directly use the CLONE and hence networks requests are way faster.
I've played with the OfflineExampleClone, and it works very well : I'm
able to launch a MASTER repository and its corresponding CLONE, and
whether I'm commiting in the MASTER or the CLONE changes are propagated
to the other repository thanks to the IRepositorySynchronizer. Notice
that in our case, we do not want to provide offline-mode support : if
the MASTER connection breaks, the user will not be able to do anything.
However, I still have some issues to tackle before being able to use
this solution on our software:
1. Cross-repository locks :
With my current prototype, whether I'm locking elements on CLONE or
MASTER, locks are not propagated to the other repository. This is
problematic for us, as we rely on a fine-grained lock mechanism that
automatically locks modified elements to prevent from any conflict. We
do not want (expect if we have no other solution) to allow conflicts
that would be resolved through a merge tool.
In other words, I would like to implement a mechanism that makes sure
that we only allow to lock objects on the CLONE if it is possible to
also lock the same objects on the MASTER.
2. Remote changes integration
For the same reasons, we would like to be sure that changes made on the
master repository have been integrated before being able to lock elements.
For example :
- User 1 makes a modification on an element E1 of the MASTER repository
=> locks are taken on both the MASTER and the CLONE repository
- User 2 cannot change E1 as it is locked on both repositories
- User 1 commits his modifications => locks are released on both the
- User 2 should not be able to make changes on E1 as long as the changes
made by User 1 have not been propagated to the CLONE
Do you have tips or reference documentation about how to implement those
2 mechanisms ?
To make things more difficult, the software depends on CDO 4.0.2, and
not the latest CDO version...
Best regards, and thank you very much for your help !
Alex
| Re: [CDO] Server replication mechanism [message #990168 is a reply to message #990163] |
Tue, 11 December 2012 04:06   |
Eike Stepper Messages: 5154 Registered: July 2009 |
Am 11.12.2012 09:31, schrieb Alex Lagarde:
> I've got some questions related to the IRepositorySynchronizer mechanism in CDO, in case you have advices before I
> The issue is that the users are located in a city, and the CDO server in another one. In result, the performances
> (especially when loading models) are not acceptable for the end-users, because of the poor network. On another hand,
> when deploying the server in their city the users are satisfied by the tool performances.
> That is why I'm currently trying to set up a replication mechanism: we would like to have a MASTER server in city A,
> and a CLONE (potentially many clones) of this server in the city B (the users's city). This will allow to improve
> performances especially when loading their models, as users directly use the CLONE and hence networks requests are way
> faster.
That makes sense.
Please have a look at http://thegordian.blogspot.de/2012/11/use-online-data-offline.html , too.
> I'm able to launch a MASTER repository and its corresponding CLONE, and whether I'm commiting in the MASTER or the
> CLONE changes are propagated to the other repository thanks to the IRepositorySynchronizer. Notice that in our case,
> we do not want to provide offline-mode support : if the MASTER connection breaks, the user will not be able to do
> anything.
> However, I still have some issues to tackle before being able to use this solution on our software:
> With my current prototype, whether I'm locking elements on CLONE or MASTER, locks are not propagated to the other
> repository. This is problematic for us, as we rely on a fine-grained lock mechanism that automatically locks modified
> elements to prevent from any conflict. We do not want (expect if we have no other solution) to allow conflicts that
IIRC., only locks of durable views are replicated.
> In other words, I would like to implement a mechanism that makes sure that we only allow to lock objects on the CLONE
> if it is possible to also lock the same objects on the MASTER.
I think that's what currently happens. Locking wouldn't make sense otherwise. Have a look at SynchronizableRepository.java:
public LockObjectsResult lock(InternalView view, LockType lockType, List<CDORevisionKey> revisionKeys,
boolean recursive, long timeout)
if (view.getBranch().isLocal())
return super.lock(view, lockType, revisionKeys, recursive, timeout);
if (getState() != ONLINE)
throw new CDOException("Cannot lock in a non-local branch when clone is not connected to master");
return lockThrough(view, lockType, revisionKeys, false, timeout);
> For the same reasons, we would like to be sure that changes made on the master repository have been integrated before
That's always the case for locked objects. The LockObjectResponse transfers the latest state/revision to the requesting
party.
> For example :
> - User 1 makes a modification on an element E1 of the MASTER repository => locks are taken on both the MASTER and the
> CLONE repository
> - User 1 commits his modifications => locks are released on both the MASTER and the CLONE repository
> - User 2 should not be able to make changes on E1 as long as the changes made by User 1 have not been propagated to
> the CLONE
> Do you have tips or reference documentation about how to implement those 2 mechanisms ?
> To make things more difficult, the software depends on CDO 4.0.2, and not the latest CDO version...
I think CDO 4.2 is a must-have when it comes to offline replication.
Cheers
/Eike
http://www.esc-net.de
> Alex
| Re: [CDO] Server replication mechanism [message #990226 is a reply to message #990217] |
Tue, 11 December 2012 08:45   |
Another question: while playing with the replication mechanism, I tried
to clone a remote server. I got the following exception :
org.eclipse.net4j.signal.RemoteException:
java.lang.IllegalStateException: Can only retrieve current version 4 for
OID1 - version requested was BranchVersion[Branch[id=0, name=MAIN], v3]
org.eclipse.net4j.signal.RequestWithConfirmation.getRemoteException(RequestWithConfirmation.java:139)
org.eclipse.net4j.signal.RequestWithConfirmation.setRemoteException(RequestWithConfirmation.java:128)
org.eclipse.net4j.signal.SignalProtocol.handleRemoteException(SignalProtocol.java:446)
org.eclipse.net4j.signal.RemoteExceptionIndication.indicating(RemoteExceptionIndication.java:63)
at org.eclipse.net4j.signal.Indication.doExtendedInput(Indication.java:55)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:326)
at org.eclipse.net4j.signal.Indication.execute(Indication.java:49)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:251)
at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
I said to myself "of course this makes cense: the MASTER server I'm
trying to clone must not allow auditing, and my CLONE server does, so my
CLONE needs historical informations that my MASTER server did not keep".
However, by CLONE has exactly the same configuration as my MASTER, with
no auditing, no branching, and the same Mapping strategy. Does this
issue make cense to you ?
Alex
| Re: [CDO] Server replication mechanism [message #990292 is a reply to message #990217] |
Tue, 11 December 2012 13:03   |
Am 11.12.2012 14:13, schrieb Alex Lagarde:
> Do you think it's possible to use a CDO sever in 4.2 with clients using CDO 4.0 ? I think it would cause problems if
> net4j protocols used in cdo have evolved between 4.0 and 4.2...
No, that's not possible.
> In the SynchronizableRepository class under CDO 4.0.2, I do not see the method LockObjectsResult lock(InternalView
> view, LockType lockType, List<CDORevisionKey> revisionKeys, boolean recursive, long timeout), so it's no surprise if
> the lock propagation does not work in CDO 4.0.
Yes, lock replication had been added later by NoMagic.
Cheers
/Eike
| Re: [CDO] Server replication mechanism [message #990293 is a reply to message #990226] |
Tue, 11 December 2012 13:05   |
Am 11.12.2012 14:45, schrieb Alex Lagarde:
> Another question: while playing with the replication mechanism, I tried to clone a remote server. I got the following
> exception :
> org.eclipse.net4j.signal.RemoteException: java.lang.IllegalStateException: Can only retrieve current version 4 for
> at org.eclipse.net4j.signal.RequestWithConfirmation.getRemoteException(RequestWithConfirmation.java:139)
> at org.eclipse.net4j.signal.RequestWithConfirmation.setRemoteException(RequestWithConfirmation.java:128)
> at org.eclipse.net4j.signal.SignalProtocol.handleRemoteException(SignalProtocol.java:446)
> at org.eclipse.net4j.signal.RemoteExceptionIndication.indicating(RemoteExceptionIndication.java:63)
Is the most important part of the stack trace missing?
> I said to myself "of course this makes cense: the MASTER server I'm trying to clone must not allow auditing, and my
> CLONE server does, so my CLONE needs historical informations that my MASTER server did not keep". However, by CLONE
> has exactly the same configuration as my MASTER, with no auditing, no branching, and the same Mapping strategy. Does
> this issue make cense to you ?
For all replication scenarios all involved repositories must be in branching mode, which includes auditing.
Cheers
/Eike
| Re: [CDO] Server replication mechanism [message #990705 is a reply to message #990403] |
Thu, 13 December 2012 01:01   |
Am 12.12.2012 11:08, schrieb Alex Lagarde:
> Noted, although I wonder why: if we want to create a CLONE that does not have offline capabilities, then creating an
> offline branch is no longer a requirement. Hence shouldn't we be able to create clones without branching activated ?
> I'm just curious, nothing blocking for my use case here.
You're right. This scenario just hasn't been considered, yet. More exactly the kind of optimization specific to this
particular usage.
> I've got another question related to server replication :
> what is the best way (if possible) to plug a conflict resolver (that would for example always consider that MASTER is
> right if conflicts are found between CLONE and MASTER) directly inside the CLONE Repository?
Conflict resolution on the server-side, as any other kind of commit change set modification) is currently not possible
because the committing client wouldn't be informed about this fact and continue to use possibly stale data. It's mostly
a matter of the network protocol not being prepared for this situation. We could enhance that.
> By the way, my first experiments clearly show that using one CLONE per site instead of one central MASTER repository
> is really efficient : it reduces model loading by 3 if I use the CLONE instead of the MASTER :)
Yeah, I can well imagine.
Cheers
/Eike
| Re: [CDO] Server replication mechanism [message #990706 is a reply to message #990452] |
Thu, 13 December 2012 01:04  |
Am 12.12.2012 15:55, schrieb Alex Lagarde:
> Yet another question :)
> I've built a clone-capabable cdo server (by extending the CDOServerApplication and adding synchronization capabilities
> similary to the OfflineCloneExample), and when trying to clone an already existing cdo repository I encounter a
> "Generated packages locally not available..." exception.
> It's true that my CLONE does not have the listed packages installed, but it's not an issue for the MASTER (correct me
> if I'm wrong): if I commit instances of new metamodels, then the metamodels are embedded inside the CommitDATA so that
> the server can interpret them.
Correct for master servers.
> It seems that it is not the case for the CLONE repository : how could I automatically copy new metamodels used in
> MASTER when cloning/integrating commits? Is this the expected behavior or am I doing something wrong ?
This is one of the TODOs listed in SynchronizableRepository.java: All involved packages must be pre-registered, ideally
before the repo starts for the first time. See IRepository.setInitialPackages().
Cheers
/Eike
Current Time: Fri May 24 00:26:58 EDT 2013
Powered by FUDForum. Page generated in 0.02179 seconds
