| [Syntactic predicates] Choosing alternative path 2 [message #989871] |
Sat, 08 December 2012 16:49  |
Boris Brodski Messages: 55 Registered: July 2009 |
Member |
I have a very small grammar (simplified part of Xbase) with a common problem:
warning(200): ../org.xtext.example.mydsl/src-gen/org/xtext/example/mydsl/parser/antlr/internal/InternalMyDsl.g:186:2: Decision can match input such as
"'<' RULE_ID '>' {RULE_ID, '<'}" using multiple alternatives: 1, 2
As a result, alternative(s) 2 were disabled for that input
I know, how to choose alternative 1 hiding the warning, but how to choose alternative 2?
Here are the details:
I want to parse ID, comparation of ID, and IDs with generics '<String>' (just like method calls in Xtend '<String>myMethod(null)')
The grammar without syntactic predicates:
Model: (expressions += Comparation)*;
Comparation returns Expression:
NumberExpression ({Comparation.left=current} op=('<' | '>') right=NumberExpression)*;
NumberExpression returns Expression:
({NumberExpression} value=NumberLiteral)
NumberLiteral:
('<' type=ID '>')?
value=ID
This grammar accepts multiple expressions, like
print
<String>print
a > b
<String>getA < <String>getB
Changing the Comparation rule to the
NumberExpression ( =>({Comparation.left=current} op=('<' | '>')) right=NumberExpression)*;
I can choose alternative 1 and get ride of the warning. Now, the input like
get parsed like
(Xtend has the same issue, by the way)
Now I would like to choose the second alternative, so that the input above would get parsed, like a call to "print" and then a call to "<String>getA".
Within the ANTLR it's possible adding following gated semantic predicate:
('<' RULE_INT '>' RULE_INT)=>
after the '*' in the Comparation rule. So mixing Xtext and ANTLR it would be:
NumberExpression {Comparation.left=current} op=('<' | '>') right=NumberExpression)* ANTLR>>> ('<' RULE_INT '>' RULE_INT)=> <<<ANTLR;
Now is it possible to do this in the Xtext?
Is it possible to add such gated semantic predicate at the generation time right to the ANTLR grammar, if no better ways are available?
Thank you and sorry for the long post!
Boris Brodski
| Re: [Syntactic predicates] Choosing alternative path 2 [message #989927 is a reply to message #989871] |
Mon, 10 December 2012 01:27   |
Henrik Lindberg Messages: 2427 Registered: July 2009 |
Did you try something like:
NumberLiteral:
=>(('<' type=ID '>')? value=ID)
=> is "if you can parse then next, then use that path"
Don't know if that helps in this case. I could not quite follow your
example when RULE_INT started appearing - what is RULE_INT?
- henrik
On 2012-08-12 22:49, Boris Brodski wrote:
> Hello,
> problem:
> warning(200):
> NumberLiteral:
> ('<' type=ID '>')?
> value=ID
> print
> <String>print
> a > b
> print
> <String>getA
> get parsed like
> print < String > getA
> "<String>getA".
> would be:
> <<<ANTLR;
> Best regards,
> Boris Brodski
| Re: [Syntactic predicates] Choosing alternative path 2 [message #990028 is a reply to message #989966] |
Mon, 10 December 2012 09:45  |
On 2012-10-12 10:58, Boris Brodski wrote:
> to address your last question: RULE_INT is the ANTLR name for the INT in
> the Xtext.
> I put it into the ANTLR>>> ... <<<ANTLR to indicate, that the '...' is
> native ANTLR syntax. This '...' should be
> inserted directly into the MyGrammar.g after is was generated from
> MyGrammar.xtext.
I had similar issues and I solved those with an external lexer i.e. (in
your case) deliver other tokens than < and > when facing < int >.
- henrik
FUDForum. Page generated in 0.01984 seconds
