| Eclipse view rendering issue [message #989994] |
Mon, 10 December 2012 06:21  |
Abdul Rehman Shaik Messages: 4 Registered: July 2011 |
Junior Member |
Eclipse view rendering issue: In my custom created view if I switch to another view and comeback, my view is faded out (the the view has two tabs which will be visible but the composite inside the tab all turns white). Looks like view rendering issue. Need some suggestions badly! Below is the stack trace:
org.eclipse.core.commands.common.NotDefinedException: Cannot get the parent identifier from an undefined context. com.sap.ndb.studio.modeling.tools.actionSet
at org.eclipse.core.commands.contexts.Context.getParentId(Context.java:201)
at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.getLevel(ContextSet.java:48)
at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.compare(ContextSet.java:38)
at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.compare(ContextSet.java:1)
at java.util.Arrays.mergeSort(Unknown Source)
at java.util.Arrays.sort(Unknown Source)
at java.util.Collections.sort(Unknown Source)
at org.eclipse.e4.ui.bindings.internal.ContextSet.<init>(ContextSet.java:76)
at org.eclipse.e4.ui.bindings.internal.BindingTableManager.createContextSet(BindingTableManager.java:90)
at org.eclipse.e4.ui.bindings.internal.BindingServiceImpl.setContextIds(BindingServiceImpl.java:236)
at sun.reflect.GeneratedMethodAccessor8.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:88)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:107)
at org.eclipse.e4.core.internal.contexts.EclipseContext.processScheduled(EclipseContext.java:318)
at org.eclipse.e4.core.internal.contexts.EclipseContext.set(EclipseContext.java:332)
at org.eclipse.e4.core.internal.contexts.EclipseContext.activate(EclipseContext.java:630)
at org.eclipse.e4.core.internal.contexts.EclipseContext.activateBranch(EclipseContext.java:635)
at org.eclipse.e4.ui.internal.workbench.PartActivationHistory.activate(PartActivationHistory.java:52)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:561)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:532)
at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:105)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(ContributedPartRenderer.java:61)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1447)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java:2836)
at org.eclipse.swt.widgets.Widget.wmSetFocus(Widget.java:2417)
at org.eclipse.swt.widgets.Control.WM_SETFOCUS(Control.java:5152)
at org.eclipse.swt.widgets.Tree.WM_SETFOCUS(Tree.java:7064)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4598)
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5958)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
at org.eclipse.swt.widgets.Control.forceFocus(Control.java:1098)
at org.eclipse.swt.widgets.Control.setFocus(Control.java:3303)
at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:1040)
at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:1038)
at org.eclipse.ui.part.PageBookView.setFocus(PageBookView.java:881)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.delegateSetFocus(CompatibilityPart.java:178)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:235)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:206)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:106)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$2.setFocus(ContributedPartRenderer.java:101)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer$9.mouseUp(StackRenderer.java:941)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:220)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
FUDForum. Page generated in 0.02785 seconds
