Home » Language IDEs » CDT » Generated resource conflict
Generated resource conflict [message #870711] Wed, 09 May 2012 08:24 Go to next message
Pis Lui is currently offline Pis Lui
hi everyone
I new in this forum and I have a problem to compile two same sources in differents folders in eclipse cdt. The console shows me that :
**** Build of configuration Debug for project TEST ****
**** Internal Builder is used for build ****
Build error
Generated resource conflict:
two resources of the same name: /{Name_project}/{Name_Buildconf}/{Name_folder}/{Name_file}.o
generated by different tools
tool1: GCC C Compiler
tool2: GCC C Compiler
I would like to know if I can force the compiler to compile the file, even if it has in double.
Thanks for your help.
Re: Generated resource conflict [message #871581 is a reply to message #870711] Mon, 14 May 2012 09:13 Go to previous messageGo to next message
Veaceslav Veaceslav is currently offline Veaceslav Veaceslav
Hi. Have you found a solution?
It seems that two kind of projects are mixed C and C++.
In my case there is a linked resource to the object file that gives this error
Re: Generated resource conflict [message #872491 is a reply to message #871581] Wed, 16 May 2012 04:11 Go to previous messageGo to next message
Hi.
My solution is to delete one of both files.
Re: Generated resource conflict [message #893222 is a reply to message #870711] Tue, 03 July 2012 05:28 Go to previous messageGo to next message
Steven Andresen is currently offline Steven Andresen
I too an having the same problem.
I deleted both files and it still shows conflicts
Errors occurred during the build.
Errors running builder 'CDT Builder' on project 'test'.
Internal error building project test configuration Debug
two resources of the same name: /test/Debug/.metadata/.plugins/org.eclipse.cdt.make.core/specs.o
tool1: GCC C++ Compiler
Re: Generated resource conflict [message #989812 is a reply to message #893222] Fri, 07 December 2012 19:15 Go to previous messageGo to next message
Vite Falcon is currently offline Vite Falcon
Have you found a solution to this problem? I'm having the same problem.
Re: Generated resource conflict [message #989820 is a reply to message #870711] Fri, 07 December 2012 21:13 Go to previous message
It appears to be a conflict in package resources requiring different compiler configurations for the particular routines and libraries. I have found many eclipse packaged libraries that were not compatible in any way with each other. I would suggest removing any unnecessary packages and keep your source related to a single package.
I never found a working resolution to the original problem. But I did try it on a separate virgin machine with no other development kits installed and only selected the required package necessary for the particular source I was working with. I was able to build the source without error until I tried to import other eclipse libraries required for added extensions to the original source. Then the same errors came back.
I have since given up on the compatibility issues with eclipse packages and gone back to reverse engineering and using command line compilers. The idea of eclipse shared libraries is a good idea, but there is no conformity from the contributors allowing for mixed libraries. You would have to completely rewrite the libraries before you can merge them into the sources.
Previous Topic:After building I get strange errors
Next Topic:Custom build
Current Time: Fri May 24 03:20:22 EDT 2013
Powered by FUDForum. Page generated in 0.09711 seconds
