Home » Eclipse Projects » Rich Client Platform (RCP) » Create TreeViewer using Workspace Content
icon5.gif  Create TreeViewer using Workspace Content [message #989063] Tue, 04 December 2012 08:47 Go to next message
Diogo Falcao is currently offline Diogo Falcao
How can i set the content of TreeViewer, using informations from a workspace?
Load files, projects and etc from the workspace on the treeviewer?
Re: Create TreeViewer using Workspace Content [message #989141 is a reply to message #989063] Tue, 04 December 2012 14:14 Go to previous messageGo to next message
John Steele is currently offline John Steele
Member
Get the workspace root:
IWorkspaceRoot root = ResourcesPlugin.getWorkspace().getRoot();
Get the projects:
IProject [] projects = root.getProjects()
viewer.setInput(projects)
Create your viewer, content provider, and label provider. You can set the input to the viewer as the array of projects or the workspace root.
Your content/label provider will need to use instanceof to determine the type of object you are currently working with, cast it, then return the respective property value.
You could also check out the common navigator framework.
[Updated on: Tue, 04 December 2012 14:16]
Report message to a moderator
Re: Create TreeViewer using Workspace Content [message #989347 is a reply to message #989063] Wed, 05 December 2012 13:38 Go to previous messageGo to next message
And how can I select a workspace and create custom projects for my RCP application? Thank you.
Re: Create TreeViewer using Workspace Content [message #989798 is a reply to message #989347] Fri, 07 December 2012 15:53 Go to previous message
Member
You will need to add the resources bundle to the project's dependencies list. As well to the launch configuration, along with it's dependencies.
You can get the workspace location by calling:
root.getLocation()
In RCP, you can get the default location by calling:
Platform.getLocation() or Platform.getInstanceLocation().
You can change the default location by specifying the -data or osgi.instance.area system propery.
Happy hunting.
Previous Topic:Can we compare two jface treeviewers model data using org.eclipse.compare
Next Topic:Contributed adapter not available
Current Time: Sun May 19 19:32:12 EDT 2013
Powered by FUDForum. Page generated in 0.01710 seconds
