I'm very new to the topic ATL and so I have a more or less basic problem.
I try to run the standard ATL example but I'm just getting a error. I imported the example over New -> Example -> ATL -> public to private. When I try to run the example I get the following error:
Are you sure to also have the Eclipse MDT-UML2 project installed?
This project provides the UML2 metamodel implementation that is automatically loaded into the EMF registry, and thus can be called by the ATL transformation runner.
Anyway "http://www.eclipse.org/uml2/2.1.0/UML" is not an actual URL, it is the URI used by EMF to identify the UML2 metamodel as loaded into its registry.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
