| Image DPI [message #989433] |
Thu, 06 December 2012 03:31  |
Jan Krakora Messages: 402 Registered: December 2009 Location: Prague |
could someone explain me how image DPI works? Or when is it taken into account?
For example when I set image size in report in px, then 300 DPI leads to three times
smaller image than 100 DPI. But when I set the image size in mm, the image is always the same size whatever the DPI is,
so in this case DPI means nothing?
What about "fit to container", is it somehow related to the DPI? Are there any differences when generating to different outputs?
What about auto vs fixed layout?
Thanks for any help.
| Re: Image DPI [message #990478 is a reply to message #990407] |
Wed, 12 December 2012 11:15  |
For the first question, I'm not sure why this is ignored. You can log a bug in the bugzilla for this. For the second question, the difference between auto and fixed has to do with page size constraints. Fixed deals with the fixed page size you defined for your masterpage, auto does not.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
FUDForum. Page generated in 0.01664 seconds
