Home » Modeling » Epsilon » [EGL] How to access to enums of a model
[EGL] How to access to enums of a model [message #989233] Wed, 05 December 2012 05:15 Go to next message
Lili R is currently offline Lili R
Hello everybody!
I am new with EGL and I want to do a model-to-text transformation (model in EMF to text). But I have the follow issue.
I have some enums and I don't know how to access to them in the ELG file and I want to show in the text generated which are the enums that the user uses in her model.
I read in the Epsilon book (ELG section), that in the dynamic sections you can use EOL code. And I saw that EOL provides the # operator to access enumerations literal. Furthermore, I used the isDefined operation (for any type).But that I realize is the this operation gives us if the object is defined in the metamodel, and that I need is if the object is defined or used in the model.
Thanks in advance!
Lili
Re: [EGL] How to access to enums of a model [message #989278 is a reply to message #989233] Wed, 05 December 2012 08:46 Go to previous messageGo to next message
Dimitris Kolovos is currently offline Dimitris Kolovos
Hi Lili,
Could you perhaps provide a minimal EGL example [1] demonstrating what you're trying to do?
Dimitris
[1] http://www.eclipse.org/epsilon/doc/articles/minimal-examples/
Re: [EGL] How to access to enums of a model [message #989306 is a reply to message #989278] Wed, 05 December 2012 10:22 Go to previous messageGo to next message
Oh! sorry. I attach a minimal example. Thanks in advance!
Lili
Re: [EGL] How to access to enums of a model [message #989380 is a reply to message #989306] Wed, 05 December 2012 17:42 Go to previous messageGo to next message
Unfortunately, I'm not able to load the default.inno model provided. The model reads
<INNO xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns="INNO">
<leadership>
<protagonist protagonist="TMT"/>
<ceo>
<pepe/>
<pepe ceoFactor="opennessToExperience"/>
<pepe ceoFactor="originality"/>
</ceo>
</leadership>
</INNO>
but there doesn't seem to be any class/feature named "pepe" in the metamodel. Any thoughts?
Dimitris
Re: [EGL] How to access to enums of a model [message #989459 is a reply to message #989380] Thu, 06 December 2012 05:12 Go to previous messageGo to next message
Yes it is my fault Sad Could you update the model with this other? Sorry for the inconveniences.
  • Attachment: default.inno
    (Size: 0.33KB, Downloaded 33 times)
Re: [EGL] How to access to enums of a model [message #989607 is a reply to message #989459] Thu, 06 December 2012 17:43 Go to previous messageGo to next message
The following seems to be doing the trick:
DETERMINANTS OF INNOVATION:
[% for (leader in Leadership) { %] [%= Leadership.name %]
The protagonist of the innovation is: [%=leader.protagonist.protagonist %]
Factors that influence in the leaders' ability and motivation to innovate:
[%for (factor in leader.ceo.ceoFactor) { %]
[%=factor.ceoFactor%]
Dimitris
Re: [EGL] How to access to enums of a model [message #989657 is a reply to message #989607] Fri, 07 December 2012 03:30 Go to previous message
Thank you so much!
Lili
Previous Topic:[Eugenia] Defining icon as link decoration
Next Topic:Cross reference problem with ETL
Current Time: Sun May 19 02:12:40 EDT 2013
Powered by FUDForum. Page generated in 0.01659 seconds
