| Set CSS3 in Web Content Settings [message #989375] |
Wed, 05 December 2012 17:08  |
Todd Keup Messages: 4 Registered: December 2012 Location: Wisconsin USA |
Junior Member |
I note that in order to use CSS3 context assist I have to set it per CSS document within a project. Does anybody know how to make CSS3 context assist the default in a PHP project?
| Re: Set CSS3 in Web Content Settings [message #989562 is a reply to message #989388] |
Thu, 06 December 2012 13:00   |
Junior Member |
Yes, I am running the latest updated versions of Juno and PDT (and WTP). I opened the Project Facet property for my PHP Project but only 3 Project Facets are displayed:
- %PHPFacet.core.label
- %PHPFacet.label
- JavaScript
There is a lock on the PHP labels so I attempted to deselect them only to get this message:
Project Facet %PHPFacet.core.label cannot be deselected. It is critical to the proper function of this project.
I noticed that if I right click on the lable I can "Unlock" it. Once I do I must also right click and unlock the %PHPFacet.label at which point I see a larger list of Project Facets including the Static Web Module you mention. If I attempt to select it I recieve an error message:
%PHPFacet.core.label 1 and Static Web Module cannot both be selected.
So I attempt to deselect it and receive the following message:
%PHPFacet.core.label 1 cannot be uninstalled.
At this time the OK button is dimmed and inactivated so I cannot change the value. Any insight?
[Updated on: Thu, 06 December 2012 13:01] Report message to a moderator
FUDForum. Page generated in 0.02727 seconds
