| Property Sheet is empty when selecting an (EMF-)object in tree viewer using a custom ViewPart [message #988505] |
Fri, 30 November 2012 04:59  |
Christoph Miksovic Messages: 12 Registered: March 2010 |
Junior Member |
Dear readers,
I have an EMF-based RCP-application that was originally generated using the genmodel-generator. The application thus has EMF.Edit end EMF.Editor components. When I run the application, I basically have an editor and a property sheet. When I select an object in the editor, the property sheet shows its properties, as expected.
Now I added a custom view part that contains a Tree viewer. Essentially the code is as follows:
public class MyCustomViewPart extends ViewPart
private ComposedAdapterFactory adapterFactory = new ComposedAdapterFactory(ComposedAdapterFactory.Descriptor.Registry.INSTANCE);
public void partActivated(IWorkbenchPartReference arg0) {
treeViewer.setContentProvider(new AdapterFactoryContentProvider(adapterFactory));
treeViewer.setLabelProvider(new AdapterFactoryLabelProvider(adapterFactory));
treeViewer.setInput(editingDomain.getResourceSet());
public void createPartControl(Composite parent)
getSite().setSelectionProvider(treeViewer);
When I now select an object in the tree viewer of MyCustomViewPart, the property sheet remains empty. When I activate the editor and select an object in the editor, the property sheet shows the proprieties of the selected objects.
Can anyone please give me a hint why the property sheet remains empty if I select an object in the tree viewer of my MyCustomViewPart?
Thank you very much for any help,
Christoph
| Re: Property Sheet is empty when selecting an (EMF-)object in tree viewer using a custom ViewPart [message #988550 is a reply to message #988505] |
Fri, 30 November 2012 07:48   |
Ed Merks Messages: 24533 Registered: July 2009 |
Christoph,
I would guess that your view part needs to implement ISelectionProvider...
On 30/11/2012 10:59 AM, Christoph Miksovic wrote:
> Dear readers,
> Christoph
| Re: Property Sheet is empty when selecting an (EMF-)object in tree viewer using a custom ViewPart [message #988857 is a reply to message #988550] |
Mon, 03 December 2012 08:25   |
Junior Member |
Hello Ed,
thank you for your reply.
I thought if would be sufficient if I register the TreeViewer within my ViewPart as a selection provider (getSite().setSelectionProvider(treeViewer)).
I use the standard org.eclipse.ui.views.properties.PropertySheet as my property view. And I can also see in the debugger that the selectionChanged method on the PropertySheet is invoked when I select an (EMF-object)element in my TreeViewer of my ViewPart (the selected element is contained in the TreeSelection object).
But the PropertySheet remains empty.
NB: When I select an element in a View that is based on org.eclipse.ui.views.ContentOutline, the properties are visible in the PropertySheet.
Can you give me some more hints if possible?
Thank you very much and cheers,
Christoph
[Updated on: Mon, 03 December 2012 08:27] Report message to a moderator
| Re: Property Sheet is empty when selecting an (EMF-)object in tree viewer using a custom ViewPart [message #989346 is a reply to message #988857] |
Wed, 05 December 2012 13:36  |
Christoph,
Comments below.
On 03/12/2012 2:25 PM, Christoph Miksovic wrote:
> Hello Ed,
Hmmm. One would hope so yes...
> I also use the standard org.eclipse.ui.views.properties.PropertySheet
> an (EMF-)element in my TreeViewer of my ViewPart (the selected element
> is contained in the TreeSelection object). But the PropertySheet
> remains empty.
> org.eclipse.ui.views.ContentOutline , the properties are visible in
> the PropertySheet.
I see. Note that the generated editor implements getAdapter to create
the appropriate properties view implementation, so you'd need to do that
too for your viewer...
Hopefully that's a good hint...
> Christoph
FUDForum. Page generated in 0.01751 seconds
