| Managing Your Target Platform with Virgo Tooling [message #967540] |
Thu, 01 November 2012 17:07  |
Dave Dresser Messages: 2 Registered: April 2010 |
Junior Member |
Software
Eclipse Juno SR 1 20120920-0800
Virgo 1.0.0.201209050002-RELEASE
I'm embarking on a project to move an product built with Eclipse PDE to Virgo. Previously we built our own target platform folder with an ant script and P2. Now it seems with Virgo Tooling that the target platform is implicitly defined by defining your Virgo Server and associating it with your Bundle Project. At first I imported our existing PDE projects and then added the 'OSGI Bundle Project Nature' to them. I was running into lots of issues resolving dependencies so I deleted all the projects and defined a new Bundle Project. I'm adding classes one by one from the old PDE project to the new Bundle Project. I'm running into two issues. First my Virgo server seems to have two locations for resolving dependencies, the usr and ext folders in the repository. As I run into an external dependency I've been copying the bundle to the usr folder of the repository. This seems to work fine for resolving dependencies but I don't know how to force Eclipse to refresh after adding new bundles to the folder. They seem to show up after quite awhile but I don't know what triggers Eclipse into recognizing that there are new bundles in the Virgo repository. Second I'm unable to resolve packages exported by org.eclipse.osgi and am wondering what is the best way to fix that.
So I have three questions:
Is there a way to convert PDE projects to Bundle projects?
Is there a way to refresh Eclipse's view of Virgo's repository folders.
I'm not finding packages exported from the org.eclipse.osgi bundle. It is present in Virgo's plugins directory but that is not exposed via the Virgo Server definition. What is the best way to pick up those exports.
| Re: Managing Your Target Platform with Virgo Tooling [message #984840 is a reply to message #967540] |
Wed, 14 November 2012 20:25   |
Leo Dos Santos Messages: 24 Registered: July 2009 |
Junior Member |
Hello Dave
Quote:Is there a way to convert PDE projects to Bundle projects?
Unfortunately there is no tool that will quickly do this for you. You'll have to take one of the approaches you've already described.
Quote:Is there a way to refresh Eclipse's view of Virgo's repository folders.
Yes, there's a couple of ways. You can open the Virgo Repository view and hit the refresh button in the Repository view tool bar, or you can open the server editor for your Virgo runtime and in the Repository page you can hit the Refresh button next to the Bundles and Libraries table. This will refresh Eclipse's knowledge of your Virgo repository. If your bundle projects don't pick up the additions right away, you can right-click the project and select the Refresh Bundle Classpath Container item from the Virgo menu.
Quote:I'm not finding packages exported from the org.eclipse.osgi bundle. It is present in Virgo's plugins directory but that is not exposed via the Virgo Server definition. What is the best way to pick up those exports.
As far as I'm aware, the plugins directory contains bundles necessary for the Virgo server to function and aren't necessarily included for reuse. The tools won't look for bundles in the plugins directory but will look in the repository subdirectories. So if you need org.eclipse.osgi you'll have to copy it to repository/ext or repository/usr
Hope that helps
- Leo
[Updated on: Wed, 14 November 2012 20:26] Report message to a moderator
FUDForum. Page generated in 0.01586 seconds
