Home » Eclipse Projects » Gemini » Gemini JPA and JNDI non jta DataSource
Gemini JPA and JNDI non jta DataSource [message #987835] Wed, 28 November 2012 05:49 Go to next message
David Schmitz is currently offline David Schmitz
Hi Mike,
is there any update on JNDI support for Gemini JPA 1.1?
I am currently trying to migrate from Aries + OpenJPA with JNDI DataSource (mentioned in persistence.xml) to Gemini JPA 1.1 and EclipseLink 2.4.1.
As I have a registered DataSource already I would like to use this one.
The described solution with the ConfigurationAdmin in Gemini JPA documentation only allows to do plain JDBC-URL, fq DriverClass etc. specification. This would be a major drawback.
Is there any way for using a JNDI DataSource with Gemini JPA 1.1?
Could you help me with this?
Kind Regards
David
Re: Gemini JPA and JNDI non jta DataSource [message #989316 is a reply to message #987835] Wed, 05 December 2012 10:58 Go to previous message
Mike Keith is currently offline Mike Keith
See reply here: http://www.eclipse.org/forums/index.php/mv/msg/242860/989315/#msg_989315
-Mike
Previous Topic:Gemini JPA + Gemini Naming
Next Topic:Gemini DBAccess 1.1.0 Milestone 4
Current Time: Sat May 25 17:33:11 EDT 2013
Powered by FUDForum. Page generated in 0.11539 seconds
