| NoSuchElementException when appending refining trace to sequence [message #989204] |
Wed, 05 December 2012 03:47  |
Andreas Brieg Messages: 48 Registered: November 2012 |
Member |
I have an ecore model where a lot of classes have 3 attributes for audit information. I want to replace these 3 attributes with a reference to a class that contains all those attributes. That class is contained in another ecore model.
Therefore I wrote the following transformation:
-- @atlcompiler atl2010
-- @nsURI ECore=http://www.eclipse.org/emf/2002/Ecore
module refactorAuditInfo;
create output: ECore refining input: ECore, additional: ECore;
rule addReferenceToAudit {
from
input : ECore!EClass (
input.eStructuralFeatures -> exists(e | e.isAuditInfoFeature())
to
auditInfoReference : ECore!EReference (
eContainingClass <- input,
eType <- input.refImmediateComposite().auditClassifier(),
name <- 'audit',
eReferenceType <- input.refImmediateComposite().auditClassifier().debug()
outputClass : ECore!EClass (
eStructuralFeatures <- input.eStructuralFeatures.append(auditInfoReference.debug())
helper context ECore!EPackage def : auditClassifier() : OclAny =
thisModule.additionalDbadm.eClassifiers -> select(e | e.name = 'Audit').first();
helper def : additionalDbadm : ECore!EPackage =
ECore!EPackage.allInstances()->select(e | e.nsURI = 'http://additional.dbadm/1.0').first();
helper context ECore!EStructuralFeature def : isAuditInfoFeature() : Boolean =
Sequence{'beDat', 'beUser', 'beRolle'}.contains(self.name);
However I get a NoSuchElementException when I execute that transformation. The output is:
additional!Audit
refiningTrace!<unnamed>
org.eclipse.m2m.atl.engine.emfvm.VMException
at __resolve__#13(refactorAuditInfo.atl)
local variables: self=refactorAuditInfo : ASMModule, value=input!beDat
at __resolve__#26(refactorAuditInfo.atl)
local variables: self=refactorAuditInfo : ASMModule, value=Sequence {input!***, input!***, input!***, input!***, input!***, input!***, input!***, input!***, input!***, input!***, input!***, input!***, refiningTrace!<unnamed>}, e=input!beDat
at __applyaddReferenceToAudit#56(refactorAuditInfo.atl[30:7-30:90])
local variables: self=refactorAuditInfo : ASMModule, link=TransientLink {rule = addReferenceToAudit, sourceElements = {input = org.eclipse.emf.ecore.impl.EClassImpl@209933c3 (name: ***) (instanceClassName: null) (abstract: false, interface: false)}, targetElements = {auditInfoReference = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@483d42d (eClass: org.eclipse.emf.ecore.impl.EClassImpl@56cb4b5d (name: Element) (instanceClassName: null) (abstract: false, interface: false)), outputClass = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@6aded8ab (eClass: org.eclipse.emf.ecore.impl.EClassImpl@56cb4b5d (name: Element) (instanceClassName: null) (abstract: false, interface: false))}, variables = {}}, input=input!***, auditInfoReference=refiningTrace!<unnamed>, outputClass=refiningTrace!<unnamed>
at __exec__#18(refactorAuditInfo.atl)
local variables: self=refactorAuditInfo : ASMModule, e=TransientLink {rule = addReferenceToAudit, sourceElements = {input = org.eclipse.emf.ecore.impl.EClassImpl@209933c3 (name: ***) (instanceClassName: null) (abstract: false, interface: false)}, targetElements = {auditInfoReference = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@483d42d (eClass: org.eclipse.emf.ecore.impl.EClassImpl@56cb4b5d (name: Element) (instanceClassName: null) (abstract: false, interface: false)), outputClass = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@6aded8ab (eClass: org.eclipse.emf.ecore.impl.EClassImpl@56cb4b5d (name: Element) (instanceClassName: null) (abstract: false, interface: false))}, variables = {}}
at main#57(refactorAuditInfo.atl)
Java Stack:
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:643)
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:388)
at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:208)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.internalLaunch(EMFVMLauncher.java:170)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMUILauncher.launch(EMFVMUILauncher.java:46)
at org.eclipse.m2m.atl.core.service.LauncherService.launch(LauncherService.java:136)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launchOrDebug(AtlLaunchConfigurationDelegate.java:300)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launch(AtlLaunchConfigurationDelegate.java:234)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:855)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:704)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1047)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1251)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: java.util.NoSuchElementException
at java.util.ArrayList$Itr.next(Unknown Source)
at org.eclipse.m2m.atl.engine.emfvm.lib.ExecEnv$173.exec(ExecEnv.java:1683)
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:391)
... 15 more
The NoSuchElementException is raised during execution of the line
Note that the line information of the ATL stack is not matching the correct line in the above ATL transformation, because I left out some other stuff.
I'm using Juno with ATL 3.3.1. Does anyone know, why this exception is raised and what I'm doing wrong? Thanks
[Updated on: Wed, 05 December 2012 03:49] Report message to a moderator
| Re: NoSuchElementException when appending refining trace to sequence [message #989271 is a reply to message #989255] |
Wed, 05 December 2012 07:54  |
Member |
I found the solution for the NoSuchElementException. When i change the VM the transformation is running in to the regular VM, then I get the error message
org.eclipse.m2m.atl.engine.vm.VMException: Could not find operation contains on Sequence(OclAny) having supertypes: [Collection(OclAny)]
at MECore!EStructuralFeature;.isAuditInfoFeature() : ??#11(refactorAuditInfo.atl[37:2-37:60])
local variables = {self=input!betId}
local stack = []
So the line
must be rewritten to
Sequence{'beDat', 'beUser', 'beRolle'}->includes(self.name);
Thanks for your help Sylvain.
FUDForum. Page generated in 0.02094 seconds
