Home » Eclipse Projects » EGL Development Tools » IDE crashes with EXCEPTION_ACCESS_VIOLATION(0.8.1 IDE crashes when opening EGL Rich UI editor)
IDE crashes with EXCEPTION_ACCESS_VIOLATION [message #989047] Tue, 04 December 2012 07:40 Go to next message
Kendall Coolidge is currently offline Kendall Coolidge
I've just downloaded and installed the 0.8.1 release onto my XP laptop and pulled in the HelloWorld sample.
When I try to open the HelloWorldView.egl file using the EGL Rich UI editor the IDE vanishes. The EGL editor opens fine.
Attached is the log that is generated.
Kendall
Re: IDE crashes with EXCEPTION_ACCESS_VIOLATION [message #989092 is a reply to message #989047] Tue, 04 December 2012 10:20 Go to previous messageGo to next message
Brian Svihovec is currently offline Brian Svihovec
Member
Kendall,
Can you try an Oracle 1.6 JRE? The 1.7 JRE is 'expected to work' according to our supported platforms page (http://wiki.eclipse.org/EDT:Supported_Platforms), but I believe we have found known issues with 1.7 in the past.
-Brian
Re: IDE crashes with EXCEPTION_ACCESS_VIOLATION [message #989096 is a reply to message #989092] Tue, 04 December 2012 10:25 Go to previous messageGo to next message
Hi Brian,
How would I do that? Change my JAVA_HOME environment variable?
Kendall
Re: IDE crashes with EXCEPTION_ACCESS_VIOLATION [message #989124 is a reply to message #989096] Tue, 04 December 2012 12:28 Go to previous messageGo to next message
Member
Kendall,
You can specify a specific JRE for your Eclipse installation using the Eclipse.ini file - http://wiki.eclipse.org/Eclipse.ini
-Brian
Re: IDE crashes with EXCEPTION_ACCESS_VIOLATION [message #989257 is a reply to message #989124] Wed, 05 December 2012 06:33 Go to previous messageGo to next message
Hi Brian,
I was able to switch to Java 1.6, but still getting the same error:
# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x5992719a, pid=4240, tid=5636
# Java VM: Java HotSpot(TM) Client VM (10.0-b23 mixed mode windows-x86)
# Problematic frame:
# C [WebKit.dll+0x7c719a]
Kendall
Re: IDE crashes with EXCEPTION_ACCESS_VIOLATION [message #989304 is a reply to message #989257] Wed, 05 December 2012 10:05 Go to previous messageGo to next message
Member
Kendall,
I see that the message mentions WebKit. What version of Safari are you using?
-Brian
Re: IDE crashes with EXCEPTION_ACCESS_VIOLATION [message #989470 is a reply to message #989304] Thu, 06 December 2012 05:58 Go to previous messageGo to next message
Using Safari 5.1.7, iTunes 11.0.0.163 and QuickTime 7.7.3
Re: IDE crashes with EXCEPTION_ACCESS_VIOLATION [message #989750 is a reply to message #989470] Fri, 07 December 2012 09:47 Go to previous messageGo to next message
Matt Heitz is currently offline Matt Heitz
Member
I have XP, Safari 5.1.7 and QuickTime 7.7.3 (iTunes isn't installed). The same thing happens to me with both JREs.
Re: IDE crashes with EXCEPTION_ACCESS_VIOLATION [message #989784 is a reply to message #989750] Fri, 07 December 2012 13:27 Go to previous messageGo to next message
Member
I've been unable to find a solution so far. I uninstalled Safari and the problem didn't go away. I installed an older version of Safari. That didn't help either.
On my machine, WebKit.dll is in C:\Program Files\Common Files\Apple\Apple Application Support\, and it was not removed or updated when I uninstalled and reinstalled Safari.
Re: IDE crashes with EXCEPTION_ACCESS_VIOLATION [message #989786 is a reply to message #989784] Fri, 07 December 2012 13:47 Go to previous messageGo to next message
Thanks guys for working so hard on this. FWIW, on my Win7 64-bit machine everything works fine - no Apple products installed.
Kendall
Re: IDE crashes with EXCEPTION_ACCESS_VIOLATION [message #989912 is a reply to message #989786] Sun, 09 December 2012 19:03 Go to previous messageGo to next message
Daniel Beauregard is currently offline Daniel Beauregard
I'm having the same problem as Kendall. I was running iTunes 10, now I have iTunes 11 installed which didn't change my problem. I've set Eclipse.ini to load JRE 1.6 and added "C:\Program Files\Safari\Apple Application Support\" to the front of the system path and Eclipse still loads the webkit.dll from the iTunes installation page instead of Safari's.
I found this bug and it seems like the problem we're having.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=388469
At the end of the posts, Kelly Wilkerson says to, "Make sure you are using the latest SWT jars..." Any idea how I would verify I'm running the latest and where I would fine them?
Daniel
Re: IDE crashes with EXCEPTION_ACCESS_VIOLATION [message #990006 is a reply to message #989912] Mon, 10 December 2012 07:50 Go to previous messageGo to next message
Member
Daniel,
Kelly put a link to bug 375830 next to the "latest SWT jars" comment. The bug is fixed in 3.8 M7, so I think that's what Kelly meant. (I don't know if we've ever tried running EDT on 3.8.)
-Matt
Re: IDE crashes with EXCEPTION_ACCESS_VIOLATION [message #991333 is a reply to message #990006] Tue, 18 December 2012 09:43 Go to previous messageGo to next message
Member
By the way, we opened a bug for this problem: https://bugs.eclipse.org/bugs/show_bug.cgi?id=396721
Re: IDE crashes with EXCEPTION_ACCESS_VIOLATION [message #994781 is a reply to message #991333] Fri, 28 December 2012 03:49 Go to previous message
fahua jin is currently offline fahua jin
Member
It seems a different problem with bug described in https://bugs.eclipse.org/bugs/show_bug.cgi?id=396721. Anyway, you might use the the workaround described in wiki page http://wiki.eclipse.org/EDT:SettingUpForMobile - 'How to resolve the problem "Internal Error. No more handlers" - Safari must be installed to use a SWT.WEBKIT -style Browser'.
Previous Topic:Mobile Safari Problem
Next Topic:PREREQUISITE to run EGL
Current Time: Sat May 18 08:25:29 EDT 2013
Powered by FUDForum. Page generated in 0.02764 seconds
