| file parsing [message #987833] |
Wed, 28 November 2012 05:36  |
mark j Messages: 14 Registered: November 2012 |
Junior Member |
hi All
I'am writing again for the same problem caus i didn't understand the answer then i can' fix the problem
what i'm trying to do is to parse my file, and the code is the follow
public class RunClass implements IObjectActionDelegate {
private Shell shell;
private String fileName;
private String workingPath;
private String uriPrefix;
* Constructor for Action1.
public RunClass() {
super();
* @see IObjectActionDelegate#setActivePart(IAction, IWorkbenchPart)
public void setActivePart(IAction action, IWorkbenchPart targetPart) {
shell = targetPart.getSite().getShell();
* @see IActionDelegate#run(IAction)
public void run(IAction action) {
Term ty = null;
try {
ty = getProg().getMain();
} catch (IOException e) {
// TODO Auto-generated catch block
e.printStackTrace();
* @see IActionDelegate#selectionChanged(IAction, ISelection)
public void selectionChanged(IAction action, ISelection selection) {
fileName = toFileName(selection.toString());
workingPath = toWorkingPath(selection.toString());
uriPrefix = toUriPrefix(selection.toString());
private Prog getProg() throws IOException {
/*Environment configuration*/
StandaloneSetup standalone = new StandaloneSetup();
standalone.setPlatformUri(workingPath);
Injector injector = new MyDslStandaloneSetup().createInjectorAndDoEMFRegistration();
XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
/*File parsing*/
Resource resource = resourceSet.createResource(URI.createURI(uriPrefix + fileName));
InputStream in = new FileInputStream(workingPath + fileName);
resource.load(in, resourceSet.getLoadOptions());
if(resource.getContents().size() == 0) {
System.out.println("The file is empty: no folder has been generated");
return null;
Prog model = (Prog) resource.getContents().get(0);
return model;
/* SERVICE METHODS */
private String toFileName(String name) {
int idx = getLastSeparatorIndex(name);
if (idx == -1)
return "";
return name.substring(idx + 1, name.length() - 1);
private String toWorkingPath(String name) {
IWorkspaceRoot root = ResourcesPlugin.getWorkspace().getRoot();
String path = root.getLocation().toString() + "/";
if (idx == -1)
return "";
return path + name.substring(3, idx) + "/";
private String toUriPrefix(String name) {
int idx = name.indexOf('/');
if (idx == -1)
return "";
return "platform:/resource"
+ name.substring(idx, name.lastIndexOf('/')) + "/";
private int getLastSeparatorIndex(String name) {
int idx = name.length() - 1;
while (name.charAt(idx) != '/') {
idx--;
if (idx < 0)
return -1;
return idx;
so what i don't understand is why with xtext 2.0 this code work and with the latest versione didn't and rise this exception
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Content is not allowed in prolog.
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:195)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:240)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1505)
at org.xtext.example.mydsl.ui.popup.actions.RunClass.getProg(RunClass.java:206)
at org.xtext.example.mydsl.ui.popup.actions.RunClass.run(RunClass.java:88)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1276)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3554)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3179)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: org.xml.sax.SAXParseExceptionpublicId: platform:/resource/prova/a.myDsl; systemId: platform:/resource/prova/a.myDsl; lineNumber: 4; columnNumber: 1; Content is not allowed in prolog.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:198)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:177)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:391)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(XMLScanner.java:1404)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:1014)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:625)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:488)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:819)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:748)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:123)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1208)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:525)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:392)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
... 34 more
[Updated on: Wed, 28 November 2012 05:37] Report message to a moderator
| Re: file parsing [message #989272 is a reply to message #989218] |
Wed, 05 December 2012 07:58  |
Sebastian Zarnekow Messages: 2788 Registered: July 2009 |
Am 05.12.12 10:31, schrieb mark j:
> i didn't , i figured is did automatically.. no??
> if not can u give some documentation or example to do it.
> thanx
Make sure the plugin.xml of your runtime project uses the right file
extension.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Go visit: http://xtext.itemis.com
FUDForum. Page generated in 0.02362 seconds
