Home » Eclipse Projects » Remote Application Platform (RAP) » JFace TableViewer/Table setitemcount() slow(decreasing itemcount from large number terrible slow)
JFace TableViewer/Table setitemcount() slow [message #989198] Wed, 05 December 2012 03:25 Go to next message
Mitch B. is currently offline Mitch B.
(I posted this topic already in the JFace-Section without any answers yet)
I use a virtual tableviewer in Eclipse RAP 1.5 to hold and display large datasets. After doing filter actions I set the itemcount to the new number of data rows which could be displayed. Now I noticed that when I decrease the number in setitemcount() from a large number above 80k to a much smaller number like 700 or so, the disposing of the items(even they were not visable) takes so much time that the user could think the application is frozen. Is this an RAP issue only, my fault or a common problem?
As a workaround I decrease the itemcount in small steps, which improves the performance a lot, but this should not the way to handle this scenario.
regards
Re: JFace TableViewer/Table setitemcount() slow [message #989447 is a reply to message #989198] Thu, 06 December 2012 04:30 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan Furnadjiev
Hi Mitch,
this is an interesting issue. Could you try to reproduce it with a plain
virtual Table (without TableViewer). This will eliminate the JFace code
and will allow as to track the issue down.
Best,
Ivan
On 12/5/2012 10:25 AM, Mitch B. wrote:
> yet)
> this scenario.
> regards
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: JFace TableViewer/Table setitemcount() slow [message #989541 is a reply to message #989447] Thu, 06 December 2012 11:45 Go to previous messageGo to next message
Hi Ivan,
just had look at the TableTab from the Controls-Demo, its a plain virtual swt table if enabled - you can reproduce it easily there.
Re: JFace TableViewer/Table setitemcount() slow [message #989719 is a reply to message #989541] Fri, 07 December 2012 07:26 Go to previous messageGo to next message
Hi Mitch,
you are absolutely right - there is a performance problem. I did a profiling with YourKit and it shows that most of the time is spent in Table#getHeaderHeight(). We should buffer header height and not query the themeing subsystem all the time. Please open a bugzilla about this issue.
Best,
Ivan
Re: JFace TableViewer/Table setitemcount() slow [message #989971 is a reply to message #989719] Mon, 10 December 2012 05:17 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=396172
Re: JFace TableViewer/Table setitemcount() slow [message #989992 is a reply to message #989971] Mon, 10 December 2012 06:11 Go to previous message
Ivan Furnadjiev
Previous Topic:RAP 2.0 tool issue
Next Topic:ControlDecoration format description
Current Time: Wed May 22 22:11:00 EDT 2013
Powered by FUDForum. Page generated in 0.01751 seconds
