Home » Newcomers » Newcomers » error while opening eclipse(error while opening eclipse)
error while opening eclipse [message #808399] Mon, 27 February 2012 13:48 Go to next message
Jorge Jacome is currently offline Jorge Jacome
Hi All, meanwhile opening eclipse it says that an error has ocurred please check the log. and this is what I can see on my log can someone help me with this issue. Regards
!SESSION 2012-02-27 12:29:30.327 -----------------------------------------------
eclipse.buildId=M20070212-1330
java.version=1.7.0_01
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.common 4 0 2012-02-27 12:29:31.171
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Bundle-RequiredExecutionEnvironment: CDC-1.0/Foundation-1.0,J2SE-1.3
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:294)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:329)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1046)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:573)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:495)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:275)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:455)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:189)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:291)
!ENTRY org.eclipse.update.configurator 4 0 2012-02-27 12:29:31.202
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Bundle-RequiredExecutionEnvironment: J2SE-1.4,CDC-1.0/Foundation-1.0,J2SE-1.3
!ENTRY org.eclipse.core.runtime 4 0 2012-02-27 12:29:31.202
!STACK 0
!ENTRY org.eclipse.osgi 4 0 2012-02-27 12:29:31.218
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.common_3.2.0.v20060603.jar/ was not resolved.
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.update.configurator_3.2.2.R32x_v20070111.jar/ was not resolved.
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime_3.2.0.v20060603.jar/ was not resolved.
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:65)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.osgi 2 0 2012-02-27 12:29:31.405
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-02-27 12:29:31.405
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.common_3.2.0.v20060603.jar/ [1] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.common 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing Constraint: Bundle-RequiredExecutionEnvironment: CDC-1.0/Foundation-1.0,J2SE-1.3
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.update.configurator_3.2.2.R32x_v20070111.jar/ [2] was not resolved.
!SUBENTRY 2 org.eclipse.update.configurator 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.eclipse.equinox.common_[3.2.0,4.0.0).
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime_3.2.0.v20060603.jar/ [3] was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.eclipse.core.jobs_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.equinox.registry_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.equinox.preferences_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.contenttype_[3.2.0,4.0.0).
!MESSAGE Missing optionally required bundle org.eclipse.core.runtime.compatibility.auth_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/com.ibm.etools.emf.event_3.0.0.v20060918_M.jar [4] was not resolved.
!SUBENTRY 2 com.ibm.etools.emf.event 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.eclipse.emf.ecore_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.core.runtime.compatibility_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.runtime_[2.1.0,4.0.0).
!MESSAGE Bundle update@plugins/com.ibm.icu_3.4.5.20061213.jar [6] was not resolved.
!SUBENTRY 2 com.ibm.icu 2 0 2012-02-27 12:29:31.405
!MESSAGE Bundle update@plugins/com.jcraft.jsch_0.1.28.jar [7] was not resolved.
!SUBENTRY 2 com.jcraft.jsch 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing Constraint: Bundle-RequiredExecutionEnvironment: J2SE-1.4
!MESSAGE Bundle update@plugins/org.apache.ant_1.6.5/ [8] was not resolved.
!SUBENTRY 2 org.apache.ant 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing Constraint: Bundle-RequiredExecutionEnvironment: J2SE-1.2
!MESSAGE Bundle update@plugins/org.apache.axis_1.3.0.v200608161946/ [9] was not resolved.
!SUBENTRY 2 org.apache.axis 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.apache.ant_[1.6.5,1.7.0).
!MESSAGE Missing optionally required bundle org.apache.commons.httpclient_[3.0.0,4.0.0).
!MESSAGE Bundle update@plugins/org.apache.lucene_1.4.103.v20060601/ [13] was not resolved.
!SUBENTRY 2 org.apache.lucene 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing Constraint: Bundle-RequiredExecutionEnvironment: J2SE-1.3
!MESSAGE Bundle update@plugins/org.apache.wsil4j_1.0.0.v200608161946/ [14] was not resolved.
!SUBENTRY 2 org.apache.wsil4j 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.uddi4j_[2.0.4,2.1.0).
!MESSAGE Missing required bundle org.apache.axis_[1.3.0,1.4.0).
!MESSAGE Bundle update@plugins/org.eclipse.ant.core_3.1.100.v20060531.jar [16] was not resolved.
!SUBENTRY 2 org.eclipse.ant.core 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.eclipse.core.variables_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.runtime_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.ant.ui_3.2.1.r321_v20060828.jar [17] was not resolved.
!SUBENTRY 2 org.eclipse.ant.ui 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing optionally required bundle org.eclipse.ui.ide_[3.2.0,4.0.0).
!MESSAGE Missing optionally required bundle org.eclipse.ui.views_[3.2.0,4.0.0).
!MESSAGE Missing optionally required bundle org.eclipse.jface.text_[3.2.0,4.0.0).
!MESSAGE Missing optionally required bundle org.eclipse.ui.workbench.texteditor_[3.2.0,4.0.0).
!MESSAGE Missing optionally required bundle org.eclipse.ui.editors_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.apache.ant_1.6.5.
!MESSAGE Missing required bundle org.eclipse.ant.core_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.filesystem_[1.0.0,2.0.0).
!MESSAGE Missing required bundle org.eclipse.core.resources_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.filebuffers_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.externaltools_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.console_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.debug.core_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.debug.ui_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jdt.ui_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jdt.debug.ui_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jdt.launching_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jdt.core_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.team.core_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ltk.core.refactoring_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.expressions_[3.2.0,4.0.0).
!MESSAGE Missing imported package com.ibm.icu.text_0.0.0.
!MESSAGE Bundle update@plugins/org.eclipse.compare_3.2.1.M20060711.jar [18] was not resolved.
!SUBENTRY 2 org.eclipse.compare 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.eclipse.ui_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.resources_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jface.text_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.ide_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.views_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.workbench.texteditor_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.runtime_[3.1.0,4.0.0).
!MESSAGE Missing imported package com.ibm.icu.util_0.0.0.
!MESSAGE Bundle update@plugins/org.eclipse.core.boot_3.1.100.v20060603.jar [19] was not resolved.
!SUBENTRY 2 org.eclipse.core.boot 2 0 2012-02-27 12:29:31.405
!MESSAGE Bundle update@plugins/org.eclipse.core.commands_3.2.0.I20060605-1400.jar [20] was not resolved.
!SUBENTRY 2 org.eclipse.core.commands 2 0 2012-02-27 12:29:31.405
!MESSAGE Bundle update@plugins/org.eclipse.core.contenttype_3.2.0.v20060603.jar [21] was not resolved.
!SUBENTRY 2 org.eclipse.core.contenttype 2 0 2012-02-27 12:29:31.405
!MESSAGE Bundle update@plugins/org.eclipse.core.expressions_3.2.2.r322_v20070109a.jar [22] was not resolved.
!SUBENTRY 2 org.eclipse.core.expressions 2 0 2012-02-27 12:29:31.405
!MESSAGE Bundle update@plugins/org.eclipse.core.filebuffers_3.2.1.r321_v20060721.jar [23] was not resolved.
!SUBENTRY 2 org.eclipse.core.filebuffers 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.eclipse.text_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.core.filesystem.win32.x86_1.0.0.v20060603.jar [24] was not resolved.
!SUBENTRY 2 org.eclipse.core.filesystem.win32.x86 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing host org.eclipse.core.filesystem_[1.0.0,2.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.core.filesystem_1.0.0.v20060603.jar [25] was not resolved.
!SUBENTRY 2 org.eclipse.core.filesystem 2 0 2012-02-27 12:29:31.405
!MESSAGE Bundle update@plugins/org.eclipse.core.jobs_3.2.0.v20060603.jar [26] was not resolved.
!SUBENTRY 2 org.eclipse.core.jobs 2 0 2012-02-27 12:29:31.405
!MESSAGE Bundle update@plugins/org.eclipse.core.resources.compatibility_3.2.0.v20060603.jar [27] was not resolved.
!SUBENTRY 2 org.eclipse.core.resources.compatibility 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing host org.eclipse.core.resources_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.core.resources.win32_3.2.0.v20060603.jar [28] was not resolved.
!SUBENTRY 2 org.eclipse.core.resources.win32 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing host org.eclipse.core.resources_[3.2.0,3.3.0).
!MESSAGE Bundle update@plugins/org.eclipse.core.resources_3.2.2.R32x_v20061218.jar [29] was not resolved.
!SUBENTRY 2 org.eclipse.core.resources 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing optionally required bundle org.eclipse.ant.core_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.expressions_[3.1.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.core.runtime.compatibility.auth_3.2.0.v20060601.jar [30] was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime.compatibility.auth 2 0 2012-02-27 12:29:31.405
!MESSAGE Bundle update@plugins/org.eclipse.core.runtime.compatibility.registry_3.2.1.R32x_v20060907/ [31] was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime.compatibility.registry 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing host org.eclipse.equinox.registry_[3.2.0,3.3.0).
!MESSAGE Bundle update@plugins/org.eclipse.core.runtime.compatibility_3.1.100.v20060603.jar [32] was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime.compatibility 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.eclipse.update.configurator_[3.1.100,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.core.variables_3.1.100.v20060605.jar [34] was not resolved.
!SUBENTRY 2 org.eclipse.core.variables 2 0 2012-02-27 12:29:31.405
!MESSAGE Bundle update@plugins/org.eclipse.debug.core_3.2.1.v20060823.jar [35] was not resolved.
!SUBENTRY 2 org.eclipse.debug.core 2 0 2012-02-27 12:29:31.405
!MESSAGE Bundle update@plugins/org.eclipse.debug.ui_3.2.2.r322_v20070202.jar [36] was not resolved.
!SUBENTRY 2 org.eclipse.debug.ui 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.eclipse.help_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jface.text_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.workbench.texteditor_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.ide_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.editors_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.draw2d_3.2.2.v20070208.jar [38] was not resolved.
!SUBENTRY 2 org.eclipse.draw2d 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.eclipse.swt_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.equinox.preferences_3.2.1.R32x_v20060717.jar [79] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.preferences 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing optionally required bundle org.eclipse.equinox.registry_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.equinox.registry_3.2.1.R32x_v20060814.jar [80] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.registry 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing imported package org.eclipse.core.runtime.jobs_0.0.0.
!MESSAGE Bundle update@plugins/org.eclipse.gef_3.2.2.v20070208.jar [84] was not resolved.
!SUBENTRY 2 org.eclipse.gef 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.eclipse.draw2d_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.workbench_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jface_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.help.appserver_3.1.100.v20060602.jar [85] was not resolved.
!SUBENTRY 2 org.eclipse.help.appserver 2 0 2012-02-27 12:29:31.405
!MESSAGE Bundle update@plugins/org.eclipse.help.base_3.2.2.R322_v20061207.jar [86] was not resolved.
!SUBENTRY 2 org.eclipse.help.base 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.apache.lucene_[1.4.3,2.0.0).
!MESSAGE Missing required bundle org.eclipse.help.appserver_[3.1.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.help.ui_3.2.0.v20060602.jar [87] was not resolved.
!SUBENTRY 2 org.eclipse.help.ui 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.eclipse.help.base_[3.1.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.forms_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.help.webapp_3.2.2.R322_v20061114/ [88] was not resolved.
!SUBENTRY 2 org.eclipse.help.webapp 2 0 2012-02-27 12:29:31.405
!MESSAGE Bundle update@plugins/org.eclipse.help_3.2.2.R322_v20061213.jar [89] was not resolved.
!SUBENTRY 2 org.eclipse.help 2 0 2012-02-27 12:29:31.405
!MESSAGE Bundle update@plugins/org.eclipse.jdt.apt.core_3.2.1.R32x_v20060822-2100.jar [90] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.apt.core 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.apache.ant_[1.6.5,1.6.6).
!MESSAGE Bundle update@plugins/org.eclipse.jdt.apt.ui_3.2.1.R32x_v20060822-2100.jar [91] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.apt.ui 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.eclipse.jdt.apt.core_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.jdt.core.manipulation_1.0.1.r321_v20060721.jar [92] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.core.manipulation 2 0 2012-02-27 12:29:31.405
!MESSAGE Bundle update@plugins/org.eclipse.jdt.core_3.2.3.v_686_R32x.jar [93] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.core 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.eclipse.text_[3.1.0,4.0.0).
!MESSAGE Missing optionally required bundle org.eclipse.team.core_[3.1.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.jdt.debug.ui_3.2.2.r322_v20061205.jar [94] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.debug.ui 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.eclipse.jdt.debug_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jdt.core.manipulation_[1.0.0,2.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.jdt.debug_3.2.2.r322_v20070130/ [95] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.debug 2 0 2012-02-27 12:29:31.405
!MESSAGE Bundle update@plugins/org.eclipse.jdt.junit.runtime_3.2.1.r321_v20060721/ [98] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.junit.runtime 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.junit_[3.8.1,3.9.0).
!MESSAGE Bundle update@plugins/org.eclipse.jdt.junit4.runtime_1.0.1.r321_v20060905.jar [99] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.junit4.runtime 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.junit4_[4.1.0,4.2.0).
!MESSAGE Missing required bundle org.eclipse.jdt.junit.runtime_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.jdt.junit_3.2.1.r321_v20060810/ [100] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.junit 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.eclipse.ui.views_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.compare_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.jdt.launching_3.2.2.r322_v20061114.jar [101] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.launching 2 0 2012-02-27 12:29:31.405
!MESSAGE Bundle update@plugins/org.eclipse.jdt.ui_3.2.2.r322_v20070124.jar [103] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.ui 2 0 2012-02-27 12:29:31.405
!MESSAGE Missing required bundle org.eclipse.ui.console_[3.1.100,4.0.0).
!MESSAGE Missing required bundle org.eclipse.help_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.search_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.team.ui_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.runtime.compatibility_[3.1.100,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ltk.ui.refactoring_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.navigator_[3.2.0,4.0.0).
!SUBENTRY 2 org.eclipse.jdt.ui 2 0 2012-02-27 12:29:31.421
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-02-27 12:29:31.421
!MESSAGE Bundle update@plugins/org.eclipse.jdt_3.2.1.r321_v20060823.jar [104] was not resolved.
!SUBENTRY 2 org.eclipse.jdt 2 0 2012-02-27 12:29:31.421
!MESSAGE Missing required bundle org.eclipse.ui.intro_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.ui.cheatsheets_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.jem.beaninfo_1.2.2.v20061027_M.jar [105] was not resolved.
!SUBENTRY 2 org.eclipse.jem.beaninfo 2 0 2012-02-27 12:29:31.421
!MESSAGE Missing required bundle org.eclipse.jem.proxy_[1.2.0,2.0.0).
!MESSAGE Missing optionally required bundle com.ibm.etools.emf.event_[3.0.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jem.workbench_[1.2.0,2.0.0).
!MESSAGE Missing required bundle org.eclipse.jem_[1.2.0,2.0.0).
!MESSAGE Missing required bundle org.eclipse.emf.ecore.xmi_[2.2.0,3.0.0).
!MESSAGE Missing optionally required bundle org.eclipse.ui_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.jem.util_[1.2.0,2.0.0).
!MESSAGE Missing required bundle org.eclipse.emf.ecore.change_[2.2.0,3.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.jem.proxy_1.2.0.v20060918_M.jar [106] was not resolved.
!SUBENTRY 2 org.eclipse.jem.proxy 2 0 2012-02-27 12:29:31.421
!MESSAGE Missing optionally required bundle org.eclipse.pde.core_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.jem.ui_1.2.1.v20060918_M.jar [109] was not resolved.
!SUBENTRY 2 org.eclipse.jem.ui 2 0 2012-02-27 12:29:31.421
!MESSAGE Missing required bundle org.eclipse.jem.beaninfo_[1.2.0,2.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.jem_1.2.1.v20060918_M.jar [112] was not resolved.
!SUBENTRY 2 org.eclipse.jem 2 0 2012-02-27 12:29:31.421
!MESSAGE Missing optionally required bundle org.eclipse.jem.proxy_[1.2.0,2.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.jface.databinding_1.0.0.I20060605-1400.jar [113] was not resolved.
!SUBENTRY 2 org.eclipse.jface.databinding 2 0 2012-02-27 12:29:31.421
!MESSAGE Missing required bundle org.eclipse.jface_[3.1.0,4.0.0).
!MESSAGE Missing optionally required bundle org.eclipse.core.runtime_[3.1.0,4.0.0).
!MESSAGE Missing optionally required bundle org.eclipse.equinox.common_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.jface.text_3.2.2.r322_v20070104.jar [114] was not resolved.
!SUBENTRY 2 org.eclipse.jface.text 2 0 2012-02-27 12:29:31.421
!MESSAGE Missing required bundle org.eclipse.core.commands_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.jface_3.2.2.M20061214-1200.jar [115] was not resolved.
!SUBENTRY 2 org.eclipse.jface 2 0 2012-02-27 12:29:31.421
!MESSAGE Bundle update@plugins/org.eclipse.jst.common.annotations.controller_1.1.1.v200609132124.jar [116] was not resolved.
!SUBENTRY 2 org.eclipse.jst.common.annotations.controller 2 0 2012-02-27 12:29:31.421
!MESSAGE Missing required bundle org.eclipse.emf.ecore_[2.2.0,2.3.0).
!MESSAGE Missing required bundle org.eclipse.wst.common.frameworks_[1.1.0,1.2.0).
!MESSAGE Missing required bundle org.eclipse.wst.common.emf_[1.1.0,1.2.0).
!MESSAGE Missing required bundle org.eclipse.jem.util_[1.2.0,1.3.0).
!MESSAGE Missing required bundle org.eclipse.jem.workbench_[1.2.0,1.3.0).
!MESSAGE Missing required bundle org.eclipse.jst.common.annotations.core_[1.1.0,1.2.0).
!MESSAGE Bundle update@plugins/org.eclipse.jst.common.annotations.core_1.1.1.v200609132124.jar [117] was not resolved.
!SUBENTRY 2 org.eclipse.jst.common.annotations.core 2 0 2012-02-27 12:29:31.421
!MESSAGE Bundle update@plugins/org.eclipse.jst.common.annotations.ui_1.1.1.v200609132124.jar [118] was not resolved.
!SUBENTRY 2 org.eclipse.jst.common.annotations.ui 2 0 2012-02-27 12:29:31.421
!MESSAGE Missing required bundle org.eclipse.jst.common.annotations.controller_[1.1.0,1.2.0).
!MESSAGE Bundle update@plugins/org.eclipse.jst.common.frameworks_1.1.4.v200702021430.jar [119] was not resolved.
!SUBENTRY 2 org.eclipse.jst.common.frameworks 2 0 2012-02-27 12:29:31.421
!MESSAGE Missing required bundle org.eclipse.emf.ecore.xmi_[2.2.0,2.3.0).
!MESSAGE Missing required bundle org.eclipse.wst.common.modulecore_[1.1.0,1.2.0).
Re: error while opening eclipse [message #898562 is a reply to message #808399] Thu, 26 July 2012 11:30 Go to previous messageGo to next message
Reed Watson is currently offline Reed Watson
I am having the same problem. I shut down eclipse last night to allow the java update that my PC said needed to be done and now eclipse will not start. I may try reverting my java and see if that works.
Re: error while opening eclipse [message #988938 is a reply to message #808399] Mon, 03 December 2012 16:36 Go to previous messageGo to next message
Scott Mitchell is currently offline Scott Mitchell
Hi Jorge,
Were you ever able to resolve this problem? I'm am having the same problem after just recently updating Java.
Scott
Re: error while opening eclipse [message #989151 is a reply to message #988938] Tue, 04 December 2012 15:46 Go to previous messageGo to next message
Steve Neill is currently offline Steve Neill
Same here... My Win XP machine did a Java update yesterday and now Eclipse won't start!
I'd be keen to find out how to fix this.
Steve
Re: error while opening eclipse [message #989155 is a reply to message #989151] Tue, 04 December 2012 16:52 Go to previous message
Russell Bateman is currently offline Russell Bateman
> Steve
http://www.eclipse.org/forums/index.php/mv/msg/441044/989070/#msg_989070
Previous Topic:Class URI for Handlers in Eclipse e4 RCP
Next Topic:Eclipse Plugin Development
Current Time: Thu May 23 18:43:57 EDT 2013
Powered by FUDForum. Page generated in 0.02008 seconds
