| Click on item in already opened context menu [message #947946] |
Wed, 17 October 2012 11:50  |
Andreas Scharf Messages: 21 Registered: December 2011 |
Junior Member |
we are using jubulas drag and drop actions to test our GEF based diagram editor. As a side-effect of this dnd operation, a context menu will be opened after the drop step.
We didn't find a way to select an item in an already opened context menu. Did I miss something? Currently we are using the arrow-key workaround mention by Oliver. However this leads to very unstable tests because we are specifying the tests on a windows machine and running them on a linux box: The number of times the down-arrow key has to pressed differs from windows to linux (on windows the first item of the context menu is already selected whereas on linux it is not).
Any recommendations?
Andreas
FUDForum. Page generated in 0.05152 seconds
