Home » Language IDEs » CDT » Indexer detects wrong include file of two possibilities
Indexer detects wrong include file of two possibilities [message #989026] Tue, 04 December 2012 05:54 Go to next message
Dirk Wibben is currently offline Dirk Wibben
Member
Hello.
I'm using Eclipse Juno with CDT 8.1 on Windows.
I'm developing software mainly for a Target microcontroller. But I have the possibility to generate code for a Simulation of the code on a PC.
To separate between 'Target' and 'Simulation' I use two different Output directories:
'Target' = 'bin'
'Simulation' = 'sim'.
Underneath those directories there is a similar tree with a header file of the same name but different content ('Target' or 'Simulation'):
<Project dir>
- bin
-- include
--- generated
---- autoconf.h
-sim
-- include
--- generated
---- autoconf.h
Somewhere in my code there is
#include <generated/autoconf.h>
And here is my problem:
When I 'follow' this include (F3 or Strg-Click), I ALWAYS get the 'autoconf.h' from sim. And therefore the Eclipse Indexer is highlighting for 'sim' and not for 'bin' as I request.
I have already inserted in
<Project Properties> | C/C++ General | Paths and Symbols | Includes | GNU C
the entry
<Project path>/bin/include
What do I have to do to create a Configuration, in which the upper 'F3' brings me to the include of the bin folder???
TIA
Dirk
Best regards
Dirk
Re: Indexer detects wrong include file of two possibilities [message #989075 is a reply to message #989026] Tue, 04 December 2012 09:33 Go to previous messageGo to next message
Axel Mueller is currently offline Axel Mueller
You should create two build configurations
http://help.eclipse.org/juno/topic/org.eclipse.cdt.doc.user/reference/cdt_u_prop_manage_dialog.htm?cp=11_4_7_0_2_0
Then in Project Properties set the source location for every build config
http://help.eclipse.org/juno/topic/org.eclipse.cdt.doc.user/reference/cdt_u_prop_general_pns_src.htm?cp=11_4_7_0_4_5_4
In C/C++ Project Properties, C/C++ Indexer
http://help.eclipse.org/juno/topic/org.eclipse.cdt.doc.user/reference/cdt_u_prop_general_idx.htm?cp=11_4_7_0_4_3
you can select which build configuration the indexer will use.
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Re: Indexer detects wrong include file of two possibilities [message #989082 is a reply to message #989075] Tue, 04 December 2012 10:01 Go to previous messageGo to next message
Member
Axel Mueller wrote on Tue, 04 December 2012 15:33
Yes . . . I understand that.
This I don't understand.
Here is my project structure (also as attachment):
index.php/fa/12593/0/
'bin' and 'sim' are in the SAME project parallel by the source folders.
The 'Source Location' for BOTH build configs would therefore be 'GV642_Premium_Bosch' !?!?
If the second point above is clear, then I fully understand the last point.
THX for the help.
Dirk
Best regards
Dirk
Re: Indexer detects wrong include file of two possibilities [message #989416 is a reply to message #989082] Thu, 06 December 2012 02:26 Go to previous messageGo to next message
Member
Sorry . . . but *BUMP*.
At least I would like to know, how/why the Indexer prefers the 'sim' directory over the 'bin' directory?
And how can I change/revert that 'attitude'?
THX in advance.
Best regards
Dirk
Re: Indexer detects wrong include file of two possibilities [message #989507 is a reply to message #989082] Thu, 06 December 2012 09:36 Go to previous messageGo to next message
You can define exclude filters for the source location.
e.g.
Config1
source location GV642_Premium_Bosch
exclude bin
Config2
exclude sim
see
Before you ask
- search this forum
- google
Re: Indexer detects wrong include file of two possibilities [message #989654 is a reply to message #989507] Fri, 07 December 2012 03:17 Go to previous messageGo to next message
Member
Hello Axel,
first THX for the reply.
I'm sorry, but that didn't work either.
I have excluded 'sim' in 'Source location' and did a 'Rebuild Index'.
Then I have navigated again and I ended again falsely in 'sim'.
This screenshot is the situation directly after the last 'F3':
index.php/fa/12630/0/
Even as 'autoconf.h' is (obviously) excluded, it is highlighted and opened in an editor. Confused
And here are the 'Indexer' settings in the PROJECT:
index.php/fa/12631/0/
Is there the possibility of a bug in CDT?
My only way to get it working properly is to RENAME the 'sim' folder and 'Rebuild Index'.
Best regards
Dirk
Re: Indexer detects wrong include file of two possibilities [message #989687 is a reply to message #989654] Fri, 07 December 2012 05:19 Go to previous messageGo to next message
Did you add sim folder in Project Properties->General->Paths and Symbols->Includes?
Before you ask
- search this forum
- google
Re: Indexer detects wrong include file of two possibilities [message #989932 is a reply to message #989687] Mon, 10 December 2012 02:07 Go to previous message
Member
Nope.
On the opposite I've even added 'bin' and 'bin\generated' as Includes with no success.
Best regards
Dirk
Previous Topic:Eclipse Sequoya fails to resolve header files
Next Topic:Definition of __STDC_HOSTED__ in Eclipse?
Current Time: Sat May 25 17:05:00 EDT 2013
Powered by FUDForum. Page generated in 0.01887 seconds
