Home » Eclipse Projects » Jubula » Check if a value lies in a range
Check if a value lies in a range [message #988250] Thu, 29 November 2012 01:12 Go to next message
Yashveer Rana is currently offline Yashveer Rana
Say i have two fields which define upper ( Field A) and lower ( Field B) ranges for a third field C.
Using ub_ctx_storeValue action, i saved the values in 2 parameters
Param1 = Field A
Param2 = Field B
Now how do i check in jubula if the value in field C lies between param1 and param2 ?
Logically speaking, i need to evaluate the expression
Param2 < Value of C < Param1
Re: Check if a value lies in a range [message #988979 is a reply to message #988250] Tue, 04 December 2012 02:10 Go to previous message
Alexandra Schladebeck is currently offline Alexandra Schladebeck
There are actions on the "Application" component that let you compare values "Check String Values" and "Check Numeric Values". They should help Smile
Alex
Previous Topic:Unable to run maven in root of checkout
Next Topic: Jubula UI Tests with multiple developers
Current Time: Mon May 20 18:25:00 EDT 2013
Powered by FUDForum. Page generated in 0.02588 seconds
