Home » Modeling » ATL » different transformed results between ATL configuration and Java programming transformation
icon5.gif  different transformed results between ATL configuration and Java programming transformation [message #988851] Mon, 03 December 2012 08:07 Go to next message
Beatus Ding is currently offline Beatus Ding
Hi everyone,I'm transforming one ".fm model" into another ".unify" model using ATL.Nothing wrong with ATL configuration.But when I try to programming launch atl transformation with the following code.I get exactly the same result,the only differences is that the prefix is gone.How to resolve the problem?
                String srcMetaURI="file:///e:/SynModel/unify.core/model/unify.ecore";
		String tgtMetaURI="file:///e:/SynModel/fm.core/model/fm.ecore";
		String srcModelURI="file:///E:/SynModel/atl/fm/generic model/new_domain.unify";
		String tgtModelURI="D:/Document/workspace_test/AGM_FM/new_domain.xml";
		String asmPath="file:///E:/SynModel/atl/fm/atl/unify2fm.asm";
		String srcMetaURI2="http://se.edu.cn/unify";
		String tgtMetaURI2="http:///featureIDE";
		register(resource(srcMetaURI, true));
		register(resource(tgtMetaURI, true));
		Resource model = resource(srcModelURI, true);
		OneInOneOutTransformation trans = new Transformations.Builder()
		.asm(asmPath)
		.in(get(srcMetaURI2), "IN", "FM")
		.out(get(tgtMetaURI2), "OUT","UNIFY")
		.buildOneInOneOut();
		EMFModel out = transform(inject(model, get(srcMetaURI2)), trans);
		out.getResource().setURI(URI.createFileURI(tgtModelURI));
		try {
			out.getResource().save(null);
		} catch (IOException e) {
			e.printStackTrace();
The result of ATL Configuration(from the graphical operation)is as follows:
<?xml version="1.0" encoding="ASCII"?>
<unify:Model xmlns:unify="http://se.fudan.edu.cn/unify" unify:type="FeatureModelType">
  <unify:entities unify:type="StructType" unify:variable="false">
  </unify:entities>
  <unify:attributes unify:name="chosenLayoutAlgorithm" unify:type="String" unify:value="1"/>
</unify:Model>
The result of Java programming transformation is as follows:
<unify:Model xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:unify="http://se.fudan.edu.cn/unify" type="FeatureModelType">
  <entities type="StructType" variable="false">
  </entities>
  <attributes name="chosenLayoutAlgorithm" type="String" value="1"/>
</unify:Model>
Re: different transformed results between ATL configuration and Java programming transformation [message #988908 is a reply to message #988851] Mon, 03 December 2012 11:31 Go to previous messageGo to next message
Hugo Bruneliere is currently offline Hugo Bruneliere
Your two models are actually similar: if you open them via a Model Editor/Browser, after having registered the corresponding metamodel in the EMF registry of course, you should realize this (cf. the MoDisco Model Browser for instance).
XMI is just a serialization format (among possibly others), and the difference probably comes from the fact that different serialization options have been used in the two cases.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Re: different transformed results between ATL configuration and Java programming transformation [message #988975 is a reply to message #988908] Tue, 04 December 2012 01:55 Go to previous message
Thank to Hugo for you reply.The two model looks almost the same,but when I load the model without unify prefix using "resourceSet.getResource()",but I got the error "feature xxx not found".I think the problem may lie in the option setting of the atl transformation.I tried many options,but nothing changed.
Previous Topic:Problem ATL
Next Topic:Issue in Trasformation with dot !!
Current Time: Wed May 22 05:29:55 EDT 2013
Powered by FUDForum. Page generated in 0.01447 seconds
