Home » Modeling » OCL » extending OCL MDT with "just" a temporal operator always
extending OCL MDT with "just" a temporal operator always [message #936996] Mon, 08 October 2012 10:57 Go to next message
Fi Fi is currently offline Fi Fi
Hi all,
As defined in the title, I try to add "just" a temporal operator "always"
in the MDT/OCL.
I add it in the EssentialOCL xtext grammar
EssentialOCLPrefixOperator:
	'-' | 'not'
	| 'always';
but when I try to write some constraints,
I has this error "Unresolved Operation 'Boolean::always()'"
I find that I should extend oclstdlib, pivot, etc.
but I don't know the order of changes.
what are the several steps?
Fy Za
Re: extending OCL MDT with "just" a temporal operator always [message #937006 is a reply to message #936996] Mon, 08 October 2012 11:05 Go to previous messageGo to next message
Extending the OCL grammars is possible, but not supported; no tutorials etc.
Since you are extending with something very similar to 'not' you can
search out/step through resolution of a not expression.
Ed Willink
On 08/10/2012 15:57, Fy Za wrote:
> Hi all,
> in the MDT/OCL.
> '-' | 'not'
> | 'always';
> but I don't know the order of changes. what are the several steps?
> Best regards,
> Fy Za
Re: extending OCL MDT with "just" a temporal operator always [message #971993 is a reply to message #937006] Mon, 05 November 2012 04:16 Go to previous messageGo to next message
malik malik is currently offline malik malik
Dear Fy za,
Have succeeded to extend eclipse OCL with temporal constraints?
I have seen that you are from an engineering school in France, me too. Can we collaborate together to perform such an extension?
BR
Malik
Re: extending OCL MDT with "just" a temporal operator always [message #986596 is a reply to message #971993] Wed, 21 November 2012 01:56 Go to previous messageGo to next message
Yes Malik,
you can contact me by private message
Fy Za
Re: extending OCL MDT with "just" a temporal operator always [message #988684 is a reply to message #937006] Sat, 01 December 2012 04:03 Go to previous messageGo to next message
Hi Ed,
I succeeded to extend CompleteOCL with always operator (as you said, I should follow the 'not' operator).
However, my extension was defined in the code level. I edit some classes like for example org.eclipse.ocl.examples.library.oclstdlib.OCLstdlibTables.java.
However, when I try to generate this class with some modifications defined in the OCL-2.4.oclstdlib using org.eclipse.ocl.examples.codegen.tables.model2tables.mtl,
I have many errors in org.eclipse.ocl.examples.library.oclstdlib.OCLstdlibTables.java.
What is the element that should be clicked to run the model2tables.mtl? the OCL-2.4.oclstdlib file? or all the package?
I 'd like to know if I should use this model2tables.mtl directly or using a mwe2 workflow ?
Ed Willink wrote on Mon, 08 October 2012 11:05
Ed Willink
> Hi all,
> in the MDT/OCL.
> '-' | 'not'
> | 'always';
> Best regards,
> Fy Za
Re: extending OCL MDT with "just" a temporal operator always [message #988685 is a reply to message #988684] Sat, 01 December 2012 04:20 Go to previous messageGo to next message
Don't run the *.mtl directly. Use the Generate OCLstdlib model MWE2
script. (Nearly all automation uses an MWE2 script.
Ed
On 01/12/2012 09:03, Fy Za wrote:
> Hi Ed,
Re: extending OCL MDT with "just" a temporal operator always [message #988687 is a reply to message #988685] Sat, 01 December 2012 05:00 Go to previous messageGo to next message
Hi Ed.
Thank you for the quickly reply.
I run Generate OCLstdlib model MWE2
before these 3 MWE2 (Generate Pivot Models, Generate Xtext Models, Generate All Editors) or after?
best regards,
Fy Za
Ed Willink wrote on Mon, 17 September 2012 09:27
The Acceleo builder is flaky, particularly on a 'clean' project. As with
many things in Eclipse, sometimes the incremental updates are outwitted
so sometimes you need to refresh and clean some/all projects. I hope
this fixes it.
--- hang on you said GenerateAll -- someone else said this doesn't work.
I never use it, since I know how to sequence the relevant sub-generators
https://bugs.eclipse.org/bugs/show_bug.cgi?id=389720 raised
Ed
Ed Willink wrote on Sat, 01 December 2012 04:20
Ed
Re: extending OCL MDT with "just" a temporal operator always [message #988699 is a reply to message #988687] Sat, 01 December 2012 09:27 Go to previous messageGo to next message
In principle you can just do GenerateAll but it has a registration bug.
I think
Generate OCLstdlib model,
can be run in any order; probably better to run Generate Xtext Models
before Generate All Editors (or just one of the editors).
Ed Willink
On 01/12/2012 10:00, Fy Za wrote:
> Hi Ed.
> best regards,
> Fy Za
>> Hi
>> with many things in Eclipse, sometimes the incremental updates are
>> outwitted so sometimes you need to refresh and clean some/all
>> projects. I hope this fixes it.
>> Regards
>> Ed
>> Hi
>> Regards
>> Ed
Re: extending OCL MDT with "just" a temporal operator always [message #988950 is a reply to message #988699] Mon, 03 December 2012 20:56 Go to previous messageGo to next message
Thank you Ed,
Finally, It works Wink
I have a question about AST and CST.
There is an article or a document with explains the difference
between these two trees? And what is the appropriate one can be
used to transform these extended constraints into LTL properties?
Fy Za.
Re: extending OCL MDT with "just" a temporal operator alwa [message #989018 is a reply to message #988950] Tue, 04 December 2012 05:38 Go to previous messageGo to next message
All my presentations are on: http://wiki.eclipse.org/MDT/OCL/Articles
http://www.eclipse.org/modeling/mdt/ocl/docs/publications/MODELS2010OCLWorkshop%5Coclxtext.pdf
deals with ASTs and CSTs.
I don't understand "the appropriate one can be used to transform these
extended constraints into LTL properties".
Ed Willink
On 04/12/2012 01:56, Fy Za wrote:
> Thank you Ed,
> Finally, It works ;)
> There is an article or a document with explains the difference between
> these two trees? And what is the appropriate one can be used to
> Best regards,
> Fy Za.
Re: extending OCL MDT with "just" a temporal operator alwa [message #989558 is a reply to message #989018] Thu, 06 December 2012 12:43 Go to previous messageGo to next message
Thank you Ed for references.
I mean what is the richer than the other with information?
CST include AST?
or AST include CST?
there is some examples about an OCL document with its AST and its CST
in order that I understand the difference between them?
How I can find code to serialize an OCL document into a CST form?
Fy Za
Ed Willink wrote on Tue, 04 December 2012 05:38
Ed Willink
> Thank you Ed,
> Best regards,
> Fy Za.
Re: extending OCL MDT with "just" a temporal opera [message #989574 is a reply to message #989558] Thu, 06 December 2012 14:39 Go to previous message
The CST is Xtext friendly. Just save the Xtext resource.
The AST is OMG-defined.
Try looking at the examples/Junit tests.
Ed Willink
> CST include AST? or AST include CST?
> Best regards,
> Fy Za
>> Hi
>> these extended constraints into LTL properties".
>> Regards
>> Ed Willink
>> > Thank you Ed,
>> between > these two trees? And what is the appropriate one can be
>> used to > transform these extended constraints into LTL properties?
>> > Best regards,
>> > Fy Za.
Previous Topic:OCL parsing without a model?
Next Topic:OCL in Xtext editor: Quick fixes for constraints
Current Time: Sat May 25 22:56:40 EDT 2013
Powered by FUDForum. Page generated in 0.01888 seconds
