Home » Eclipse Projects » BIRT » birt web viewer (webviewerexample) , build from which repository?
birt web viewer (webviewerexample) , build from which repository? [message #988936] Mon, 03 December 2012 16:05 Go to next message
nari noori is currently offline nari noori
i need to build from latest birt web viewer source.
There are so many versions in the eclipse cvs, dont know what version is the latest.
its possible to download the compiled build birt_runtime-4.2.1 from http://download.eclipse.org/birt/downloads/,
but when i see the source in the birt cvs, i cant see the birt web viewer newer than version 3.7?
i found this article. It says to build from tag with version 3.7.
http://wiki.eclipse.org/BIRT/FAQ/Birt_Project#Q:_How_do_I_export_the_3.7_BIRT_web_viewer.3F
im confused, i cant find the 4.2.1 source in the cvs, none later than version 3.7...maybe i should skip using the tag 3.7 in cvs repository and just use the source from HEAD ? (is it latest stable?)
[Updated on: Mon, 03 December 2012 16:10]
Report message to a moderator
Re: birt web viewer (webviewerexample) , build from which repository? [message #988970 is a reply to message #988936] Tue, 04 December 2012 01:20 Go to previous message
Michael Williams is currently offline Michael Williams
The source is now on git. http://git.eclipse.org/c/birt/org.eclipse.birt.git
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Previous Topic:Merge Two Different Grids
Next Topic:BIRT + web application
Current Time: Tue May 21 15:56:27 EDT 2013
Powered by FUDForum. Page generated in 0.01501 seconds
