Home » Modeling » EMF » [CDO] OCL Query to sql(How the query result is generated?)
[CDO] OCL Query to sql [message #988932] Mon, 03 December 2012 15:46 Go to next message
Michele Preti is currently offline Michele Preti
Hi, i'm trying to figure out if CDO suit my needs, and i have writ a simple test, for now the topic is Queries.
I really like the idea of using OCL as and abstracted language indipendent from the DBStore but when i have tryed to find the sqlQuery corresponding to my OCL query in the trace file i can't find it.
Now i have the doubt that OCL didn't convert to sql but instead load all objects in memory and apply the constraints. Am i right?
My OCL query was "Foo.allInstances()->select(f:Foo|f.xyz='test')" but in the trace file there is no a where clause with xyz = 'test' (or something like). At least...can't find it.
Re: [CDO] OCL Query to sql [message #988972 is a reply to message #988932] Tue, 04 December 2012 01:31 Go to previous messageGo to next message
Eike Stepper is currently offline Eike Stepper
Am 03.12.2012 21:46, schrieb Michele Preti:
> Am i right?
You're right, CDO does not translate OCL to SQL. It integrates with OCL at the "extents map" level, where it provides
lazy extents.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] OCL Query to sql [message #989022 is a reply to message #988972] Tue, 04 December 2012 05:46 Go to previous message
Istvan Rath has done performance benchmarks that demonstrate that
provided the server memory is large enough the direct OCL approach is an
order of magnitude faster than SQL.
http://www.eclipse.org/modeling/mdt/ocl/docs/publications/EclipseConEurope2012/FastQueries.pdf
slide 5 for a quick result. See Istvan's publications for extensive
results and descriptions.
Ed Willink
>> it.
> OCL at the "extents map" level, where it provides lazy extents.
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Previous Topic:[CDO] get deleted Revision/CDOObject
Next Topic:[CDO] ClassCastException when removing one entry from the model
Current Time: Wed May 22 07:14:03 EDT 2013
Powered by FUDForum. Page generated in 0.01816 seconds
