| How to back with result? [message #960366] |
Sat, 27 October 2012 08:13  |
Marcin Bicz Messages: 1 Registered: October 2012 |
Junior Member |
We want create orion plugin that allows you to add image url. There should be button in editor that open new window (google search image), you select image and than back with result to editor. Result should be url.
| Re: How to back with result? [message #988892 is a reply to message #968755] |
Mon, 03 December 2012 10:03  |
Mark Macdonald Messages: 11 Registered: July 2009 |
Junior Member |
Rafael Chaves wrote on Fri, 02 November 2012 14:26Ken, Szymon states on that issue:
"They had to disable sandboxing to proceed"
What does that mean? Is it a browser setting?
I think Szymon meant modifying the Orion plugin registry to disable the "sandbox" flag on plugin IFRAMES. This would allow a plugin to access the containing page's window, essentially giving the plugin full control over Orion and all the services connected to it -- which is clearly dangerous from a security standpoint. So it's not a browser setting, but requires modifying Orion code.
[Updated on: Mon, 03 December 2012 10:04] Report message to a moderator
FUDForum. Page generated in 0.22577 seconds
