Home » Modeling » ATL » Problem ATL
Problem ATL [message #988633] Fri, 30 November 2012 13:49 Go to next message
Rafael Durelli is currently offline Rafael Durelli
Member
Hello guys, i'm new at ATL and I'm trying to create a simple transformation that transform a SQLMODEL, which I've devised, to a KDMSQL, which correspond to a extension to the KDM to model SQL statements. However, when I have to create the Datatype I always get an exception. Please, see the code below
-- @path MM=/SQLMODEL/model/sqlmodel.ecore
-- @path MM1=/KDMSQLExtesion/model/kdmSQL.ecore
module transformation;
create OUT : MM1 from IN : MM;
rule table2TableUnit {
	from
		table : MM!Table
	to
		tableUnit : MM1!TableUnit (
			name <- table.name,
			codeElement <- table.columns
rule column2ColumnUnit {
	from
		column : MM!Column
	to
		columnUnit : MM1!ColumnUnit (
			name <- column.name,
			type <- column.type //the error of Casting is happing here.
                       //type is Datatype and column.type is a String, how can I create a Datatype correctly?
Thanks guys, please help.
Re: Problem ATL [message #988693 is a reply to message #988633] Sat, 01 December 2012 06:50 Go to previous messageGo to next message
Member
Someone knows how to fix it? Please let me know. Thanks.
Re: Problem ATL [message #988814 is a reply to message #988693] Mon, 03 December 2012 05:31 Go to previous messageGo to next message
Member
	from
		table : MM!Table
	to
			name <- table.name,
	from
		column : MM!Column
	to
			type.name <- column.type -- Herein is the problem...
I have been tried make type.name (String) <- column.type (also string) but the source code don't compile. Could someone please help me on this?
Re: Problem ATL [message #988816 is a reply to message #988633] Mon, 03 December 2012 05:34 Go to previous messageGo to next message
Member
	from
		table : MM!Table
	to
			name <- table.name,
	from
		column : MM!Column
	to
Re: Problem ATL [message #988822 is a reply to message #988816] Mon, 03 December 2012 05:58 Go to previous messageGo to next message
Sylvain EVEILLARD is currently offline Sylvain EVEILLARD
	from
		column : MM!Column
	to
			type <- type
		type : MM1!Datatype (
			name <- column.type
Re: Problem ATL [message #988849 is a reply to message #988822] Mon, 03 December 2012 08:03 Go to previous message
Member
Thanks Sylvain EVEILLARD. It worked.
Previous Topic:Accessing Data Type Converters
Next Topic:different transformed results between ATL configuration and Java programming transformation
Current Time: Sat May 25 11:48:59 EDT 2013
Powered by FUDForum. Page generated in 0.01882 seconds
