Home » Eclipse Projects » BIRT » BIRT + web application
BIRT + web application [message #988324] Thu, 29 November 2012 07:06 Go to next message
Moojan Kh is currently offline Moojan Kh
I'm new in BIRT.
I want to know could I create a chart and open it by web browser?
for example:
I have a web application project, my IDE is e-clips.
in one page, I need to show my result by charts and graphs.
can I import BIRT chart in my page,which at the end it can be shown in my browser.
I will be thankful if you help me with that.
[Updated on: Thu, 29 November 2012 08:39]
Report message to a moderator
Re: BIRT + web application [message #988441 is a reply to message #988324] Thu, 29 November 2012 16:53 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
You can do this a couple of ways. Use the WTP integration package and add the charting servlet or write your own chart servlet. Another option is to deploy BIRT runtime and build your charts in the BIRT designer. This adds a bit more overhead, but may be a bit more easy to maintain. If you want an example of a chart servlet let me know. There should be one on BIRT exchange.
Jason
Jason Weathersby
BIRT Exchange
Re: BIRT + web application [message #988466 is a reply to message #988441] Thu, 29 November 2012 22:07 Go to previous messageGo to next message
I apply for your second option, The BIRT runtime.
Now i'm stuck on the integration of BIRT to my web application.
the problem is that i cannot access to //localhost:8080/manager/html
is there any solution?
Re: BIRT + web application [message #988588 is a reply to message #988466] Fri, 30 November 2012 10:42 Go to previous messageGo to next message
now i want to get access to my database which is in PhpMyadmin!!!
But how???
Re: BIRT + web application [message #989091 is a reply to message #988588] Tue, 04 December 2012 10:20 Go to previous message
I am a bit confused. Did you deploy the runtime to tomcat?
Jason
Jason Weathersby
BIRT Exchange
Previous Topic:birt web viewer (webviewerexample) , build from which repository?
Next Topic:BIRT Runtime on Solaris Sparc
Current Time: Mon May 20 18:13:00 EDT 2013
Powered by FUDForum. Page generated in 0.05594 seconds
