Home » Modeling » Papyrus » A new version of tutorial
A new version of tutorial [message #988581] Fri, 30 November 2012 10:26 Go to next message
Mary P. is currently offline Mary P.
Member
Hello!
Can I provide a modified version of "Papyrus Tutorial: How to create a new Papyrus UML Diagram" adapted to Eclipse Juno to the Eclipse Community?
The old version (http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papyrus/trunk/examples/others/org.eclipse.papyrus.example.diagram.simplediagram/docs/PapyrusDevelopperTutorial_OnDiagramCreating.odt) is based on Eclipse MT Helios
As you know, I asked a lot of questions when I tried to complete the Tutorial using Eclipse Juno. Eventually I managed to complete it and I found out quite a lot of modifications (like the names of packages, modifications of plugin.xml file, etc) and some steps that were a bit unclear for me (for the very beginner:)). Maybe some of this information could be useful for other people!
So, if you let me provide a modified version of Tutorial, that would be really great! And if it is possible, I would like to know, what should be the procedure and whom can I send the modified version for revision?
Thanks in advance!
Mary
Re: A new version of tutorial [message #988700 is a reply to message #988581] Sat, 01 December 2012 09:33 Go to previous messageGo to next message
I'm not a Papyrus committer, but good quality contributions are
generally encouraged. We are all too busy to do everything ourselves.
Eclipse IP processes require traceability of authorship and this is
eased by forking the relevant Papyrus GIT through its GitHub mirror.
I recommend creating your own public GitHub fork and making the changes
there. Raise a Bugzilla identifying what you are doing. When ready a
Papyrus committer can then pull your changes into the main Papyrus repo.
Ed Willink
On 30/11/2012 15:26, Mary P. wrote:
> Hello!
> Community?
> The old version
> revision?
> Thanks in advance!
> Best regards,
> Mary
Re: A new version of tutorial [message #988701 is a reply to message #988700] Sat, 01 December 2012 10:17 Go to previous messageGo to next message
Member
Thank you! Smile
Re: A new version of tutorial [message #988702 is a reply to message #988700] Sat, 01 December 2012 10:25 Go to previous messageGo to next message
Apologies. I assumed that Papyrus was in GIT, when I should have known
better.
For SVN, you'll need to develop the change, then attach a patch to the
Bugzilla.
Ed Willink
On 01/12/2012 14:33, Ed Willink wrote:
> Hi
> changes there. Raise a Bugzilla identifying what you are doing. When
> ready a Papyrus committer can then pull your changes into the main
> Papyrus repo.
> Regards
> Ed Willink
>> Hello!
>> Community?
>> The old version
>> revision?
>> Thanks in advance!
>> Best regards,
>> Mary
Re: A new version of tutorial [message #988835 is a reply to message #988701] Mon, 03 December 2012 06:46 Go to previous messageGo to next message
Joost Kraaijeveld is currently offline Joost Kraaijeveld
Hi Mary,
Could you provide me the revised tutorial somehow?
Groeten,
Joost Kraaijeveld
Re: A new version of tutorial [message #988854 is a reply to message #988835] Mon, 03 December 2012 08:20 Go to previous messageGo to next message
Member
Hello)
If I understood your question correctly....
Sorry, I don't have the revised version of the tutorial yet because I still did not find a person who can revise it and I did not add it to the SVN repository)
But as soon as I finish the modifications and the new version is revised, I will send it you!)
Mary
Re: A new version of tutorial [message #988859 is a reply to message #988854] Mon, 03 December 2012 08:35 Go to previous message
On 03-12-12 14:20, Mary P. wrote:
> Hello)
> the SVN repository)
OK, thanks.
Groeten,
Joost Kraaijeveld
Askesis B.V.
Molukkenstraat 14
6524NB Nijmegen
tel: 024-3888063 / 06-51855277
fax: 024-3608416
web: www.askesis.nl
Previous Topic:MARTE profile in uml format
Next Topic:'Child Meta Feature' must reference 'Meta Class' or its sub-classes
Current Time: Sat May 25 20:35:30 EDT 2013
Powered by FUDForum. Page generated in 0.01687 seconds
