| Best practice for building eclipse data explorer view . [message #988525] |
Fri, 30 November 2012 06:10  |
KK Mising name Messages: 2 Registered: July 2009 |
Junior Member |
Hello Experts,
Could you please clarify which is the best fit for this particular scenario ?
1. I want to build an Eclipse data explorer view(Tree based view), from there we will be connecting to third party servers and viewing the data.
2. In future, we also want to enable CRUD operations on the model objects. Means,we are planning to build modelling environment for designing the model objects.
3. End user should be able to save selected model objects into the local file system and view them in offline mode.
Considering all these usecases, what is the best fit of eclipse technologies ?
a. Should I use EMF for this ?
b. Combination of EMF and JAXB ? Do I need to serialize only model data or also with tree node (this contains additional properties like last saved of model,etc.)
Thanks a lot for your support.
| Re: Best practice for building eclipse data explorer view . [message #988567 is a reply to message #988525] |
Fri, 30 November 2012 09:17  |
Ed Merks Messages: 24529 Registered: July 2009 |
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
<body text="#000000" bgcolor="#FFFFFF">
Comments below.<br>
<br>
<div class="moz-cite-prefix">On 30/11/2012 2:35 PM, KK Mising name
wrote:<br>
</div>
<blockquote cite="mid:k9acnh$p5d$1@xxxxxxxxe.org" type="cite">Hello
Experts,
<br>
<br>
scenario ?
<br>
<br>
viewing the data.
<br>
<br>
<br>
</blockquote>
The data are model objects?<br>
<br>
<br>
</blockquote>
Generated editors support "Save as..." and EMF models can be loaded
from arbitrary URIs , which can correspond to http: URLs such that
the resource really is loaded from the internet.<br>
<br>
technologies ?
<br>
<br>
</blockquote>
Yes, maybe CDO will be a good fit too though I'm not sure what you
mean by third party servers; CDO relies CDO running on the server.<br>
<blockquote cite="mid:k9acnh$p5d$1@xxxxxxxxe.org" type="cite">b.
<br>
</blockquote>
I don't see that there's be any need to use JAXB because EMF
provides equivalent capabilities:<br>
<blockquote><a target="_out"
href="http://www.theserverside.com/tt/articles/article.tss?l=BindingXMLJava">Binding
XML to Java</a><br>
</blockquote>
I don't understand the distinction you're drawing between tree node
and the data. You can always model both. Anything you want to
persist will be good to model because you get XML serialization (or
things like Teneo's Hibernate support) for free.<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
FUDForum. Page generated in 0.02220 seconds
