| Re: There is no report design object available. exception with birt 3.7.2 [message #988781 is a reply to message #988519] |
Mon, 03 December 2012 02:16   |
Chris F Messages: 4 Registered: October 2012 |
Junior Member |
Your reports were designed in 2.5.1. When you upgraded to 4.2.1 did you upgrade the reports as well? You might want to open them up in the 4.2.1 designer and make any changes that need to be, resave, and then try. There are a lot of little differences between the two, I haven't had any report built in 2.5 migrate to 4.2 without at least touching(resaving) it in the updated designer. Got the same error "There is no report design object available". Likewise if you use a report built in 4.2.1 designer / 2.5 on your webserver - you'll see the same error.
[Updated on: Mon, 03 December 2012 02:20] Report message to a moderator
FUDForum. Page generated in 0.01925 seconds
