Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Unexpected return value from MessageBox.open()
Unexpected return value from MessageBox.open() [message #987778] Wed, 28 November 2012 02:09 Go to next message
Kevin Albrecht is currently offline Kevin Albrecht
I have created a MessageBox with the following styles: ICON_WARNING, YES, NO, and CANCEL. When I show the MessageBox using the open() method, and then close it using the "X" in the corner of the message box, the return value is -4, instead of the expected YES, NO, or CANCEL. Which SWT constant does this correspond to, and why am I not getting one of the expected styles?
My platform is 64-bit GTK, running on Ubuntu 12.10.
Kevin Albrecht
Re: Unexpected return value from MessageBox.open() [message #988436 is a reply to message #987778] Thu, 29 November 2012 16:35 Go to previous message
Grant Gayed is currently offline Grant Gayed
That looks like a bug, it should be SWT.CLOSE. I've logged
https://bugs.eclipse.org/bugs/show_bug.cgi?id=395413 .
Grant
On 11/28/2012 10:56 AM, Kevin Albrecht wrote:
> Kevin Albrecht
Previous Topic:Strike through Font?? is this possible in SWT
Next Topic:Remove Custom Contribution From Toolbar
Current Time: Sat May 18 22:17:01 EDT 2013
Powered by FUDForum. Page generated in 0.05509 seconds
