Home » Eclipse Projects » ACTF » Accessibility Check Tool for Java Apps(Accessibility Check Tool for Java Apps (with Eclipse Juno))
Accessibility Check Tool for Java Apps [message #988343] Thu, 29 November 2012 08:32
Rolf Mager is currently offline Rolf Mager
Hello all,
I am currently searching for a way to automatically check Java apps regarding accessibility. I have seen that there are example check tools for different content available using the ACTF framework (namely ACTF aDesigner).
Is there a similar check tool available for Java SWING/SWT apps which will work with Eclipse Juno? It should be something similar to the no longer maintained componentry Javaco, which does not seem to work with current Eclipse distributions; also development for Javaco was discontinued at an very early stage.
So how about an ACTF check tool for Java SWING/SWT apps.
Thanks and best wishes,
Rolf
Previous Topic:Accessibility for SWT and JFACE widgets
Next Topic:How to access Visual Editor in Indigo.?
Current Time: Tue May 28 21:06:13 EDT 2013
Powered by FUDForum. Page generated in 0.01532 seconds
