| ModelingAssistant Popup for ShapeCompartments [message #988191] |
Wed, 28 November 2012 13:28 |
Daniel König Messages: 24 Registered: November 2012 |
Junior Member |
Hello!
I had to change my compartments to ShapeCompartments (ListLayout = false).
Since I changed this I do not get the ModelingAssistant Popup anymore.
The EditPolicy should be installed by default:
org.eclipse.gmf.runtime.diagram.ui.editparts.ShapeCompartmentEditPart:
protected void createDefaultEditPolicies() {
super.createDefaultEditPolicies();
installEditPolicy(EditPolicyRoles.CREATION_ROLE,
new CreationEditPolicy());
installEditPolicy(EditPolicy.LAYOUT_ROLE, new XYLayoutEditPolicy());
installEditPolicy(EditPolicy.CONTAINER_ROLE, new ContainerEditPolicy());
// TODO: this edit policy get overriden by code at the end of this
// function
// may be this breaks some use cases; it needs to be checked
installEditPolicy(EditPolicyRoles.DRAG_DROP_ROLE,
new DiagramLinkDragDropEditPolicy());
installEditPolicy(EditPolicy.GRAPHICAL_NODE_ROLE,
new ContainerNodeEditPolicy());
// Install an edit policy for snap
installEditPolicy(EditPolicyRoles.SNAP_FEEDBACK_ROLE,
new SnapFeedbackPolicy());
new ShapeCompartmentDropEditPolicy());
installEditPolicy(EditPolicyRoles.POPUPBAR_ROLE,
new PopupBarEditPolicy());
ComponentStateCompartmentEditPart extends ShapeCompartmentEditPart:
installEditPolicy(EditPolicyRoles.SEMANTIC_ROLE, new ComponentComponentStateCompartmentItemSemanticEditPolicy());
installEditPolicy(EditPolicyRoles.CREATION_ROLE, new CreationEditPolicyWithCustomReparent(
MachineVisualIDRegistry.TYPED_INSTANCE));
installEditPolicy(EditPolicyRoles.CANONICAL_ROLE, new ComponentComponentStateCompartmentCanonicalEditPolicy());
The ModelingAssistantProvider should also be fine:
public List getTypesForPopupBar(IAdaptable host) {
IGraphicalEditPart editPart = (IGraphicalEditPart) host.getAdapter(IGraphicalEditPart.class);
if (editPart instanceof ModelEditPart) {
ArrayList<IElementType> types = new ArrayList<IElementType>(1);
types.add(MachineElementTypes.Machine_2001);
return types;
if (editPart instanceof MachineEditPart) {
types.add(MachineElementTypes.Component_3001);
return types;
if (editPart instanceof ComponentStateCompartmentEditPart) {
types.add(MachineElementTypes.State_3002);
return types;
if (editPart instanceof StateComponentValueCompartmentEditPart) {
types.add(MachineElementTypes.StateValue_3004);
return types;
return Collections.EMPTY_LIST;
Is there any way I can get the ModelingAssistant back for my ShapeCompartment?
I recognized in the ModelingAssistantProvider that the EditPart for ListCompartments is the Node itself (for example "MachineEditPart"). If it's a ShapeCompartment, the CompartmentEditPart is used ("ComponentStateCompartmentEditPart" resp. "StateComponentValueCompartmentEditPart").
Manually changing to the Node which contains the Compartment did not have any effect.
I hope someone can help me.
Thank you! :)
FUDForum. Page generated in 0.01877 seconds
